Beovision Eclipse - Software bug in latest update (2.3.xx) when swifting audio sources from Deezer to "music" DLNA
This post has 25 Replies | 3 Followers
Sweden
Posts 357
Silver Member
Martin Posted: Thu, Nov 29 2018 3:42 PM
After yesterdays softwareupdate for my Beovision Eclipse soundcenter (software 2.3.xxxx) with Airplay 2, it has arrived a software bug which is very frustrating.
The software-bug appears as follows:
If you start the Eclipse soundcenter with Deezer (thru the B&O app) or Music (DLNA-content), the Bang&Olufsen APP loses the contact with the soundcenter when you switch to another music source. So if You start the TV with Deezer, everything works perfect. But when you switch to Music (DLNA content) the B&O-app loses the contact with soundcenter and there is no cover-art, no time-mark of the song playing and no possibililty to put the music to "pause". If You after this switch back to Deezer, everything works perfect.
If You start the soundcenter with Music-source (DLNA-content), everything works perfect. BUT if you switch to Deezer the same problem occurs as described before (no coverart, no time-mark, no possibility to pause the music).
If you make a "play-list" in the B&O-app and this playlilst has content from both Deezer and music (DLNA-content) the first source that is playing works perfect. When the TV switches to content from DLNA (Music) then the contact between the soundcenter and B&O-app will not work.
Please forward this complaint to your software-developer and make a fix as soon as possible. The last software 2.2.xxxxx before the Airplay2-software worked perfect.
Best Regards
Martin Ström
SWEDEN
NEW! Beovision Eclipse 65 2nd generation (G1) with floorstand (from STB Brackets), Beolab 50 front, Beolab 3 rear, 2 x Beoplay A6 linkrooms, 2xBeoremote one BT, Beosound 9000 Mark III (sw 3.4), Beosound 5 (for DLNA only),  Philips Hue (all lights in the home), Oppo UDP-203, Apple TV 4K (2021 model). Beoremote HALO, 3xBeoplay Charging pad, Beoplay M5
Stan
Chicago-area USA
Posts 869
Stan replied on Thu, Nov 29 2018 5:31 PM
I had all kinds of strange issues yesterday after I upgraded.  After rebooting my Eclipse and my phone, they seem to have gone away.  I haven't played any DNLA sources yet.  I will try that later today.
It didn't help that I also upgraded my wifi equipment yesterday...
Stan
Chicago-area USA
Posts 869
Stan replied on Thu, Nov 29 2018 5:34 PM
sorry, duplicate post
Stan
Chicago-area USA
Posts 869
Stan replied on Thu, Nov 29 2018 6:59 PM
I can play Deezer and DNLA, and switch back and forth just fine.  I'm using the sound center's DNLA, not the TVs.
How do you create your own playlist in the Beo app?
Speaking of the app, have you noticed the "remote control" capabilities?  Including the "touch pad" screen that lets you move the cursor around and select items (similar to LG's "magic remote").
MrAndersen
Posts 226
Hi Martin
That doesn't sound good. We will take a look at this ASAP and I'll keep you updated.
Br
Thomas; Bang & Olufsen
Sweden
Posts 357
Silver Member
Martin replied on Fri, Nov 30 2018 7:24 AM
Hi Tomas,
I also talked to my dealer in Goethenburg (Sweden) and he also experienced the same fault (softwarebug after latest softwareupdate 2.3.xxx) on his Eclipse in the store.
I would really appreciate if You can make a fix as soon as possible. I use often both Deezer and my DLNA-server (Music-source on the Eclipse) and I change between these sources quite often when I play music with soundcenter.
Have a nice weekend Tomas!.
Best Regards
Martin Ström
SWEDEN
MrAndersen
Posts 226
Hi Martin
A small update. We have reproduced the error. Unfortunately this was not covered in our tests, it is now. We will look into a fix and keep you posted.
A nice weekend to you too!
Sweden
Posts 357
Silver Member
Martin replied on Fri, Nov 30 2018 9:49 AM
Hi Tomas,
Great! Thanks!
Best Regards
Aussie Michael
Melbourne, AU
Posts 3,730
MrAndersen:
Well done.
elephant
AU
Posts 8,219
elephant replied on Fri, Nov 30 2018 10:23 PM
Martin:
Like Stan I would like to know now how one does this !
BeoNut since '75
Sweden
Posts 357
Silver Member
Martin replied on Sat, Dec 1 2018 7:21 AM
Hi
What I mean with playlist is Playqueue. You can put different tracks and albums in the playqueue both from Deezer and DLNA streaming.
Sweden
Posts 357
Silver Member
Hi
Chris Townsend
Qatar
Posts 3,531
My Sky won’t select channels. I now type in a channel number and the screen just goes blue, I keep typing the number and eventually it works.
w5bno123
London
Posts 578
Chris Townsend:
My Sky won’t select channels. I now type in a channel number and the screen just goes blue, I keep typing the number and eventually it works. Beovision Eclipse, Beolit 15, Beoplay A2, H6/H2, Form 2, Beoplay A3, Beovision 5-42 connected to a DVD1
This sounds like a CEC issue. Switch of HDMI control in the sky box and on all HDMI inputs on the soundcenter even if they are not being used for anything else. As B&O use PUC control there is a conflict.
Stuart
B&O Ealing
Chris Townsend
Qatar
Posts 3,531
Thanks, I’ve no idea how to do it but I’ll crack on. CheersYes - thumbs up
Sweden
Posts 357
Silver Member
Martin replied on Mon, Dec 3 2018 9:48 AM
Hi Tomas,
When do You expect the software fix ready regarding the bug I mentioned above for the Eclipse?
Best Regards
SWEDEN
MrAndersen
Posts 226
Hi Martin
The bug is currently being investigated, but I have no ETA on a solution yet.
Br
Thomas
w5bno123
London
Posts 578
Chris Townsend:
Thanks, I’ve no idea how to do it but I’ll crack on. Cheers Beovision Eclipse, Beolit 15, Beoplay A2, H6/H2, Form 2, Beoplay A3, Beovision 5-42 connected to a DVD1
Go to each source input HDMI A-D and at the bottom of the menu you’ll see HDMI control. In your Sky Q box go to Audio Visual Settings and switch off HDMI control.
Chris Townsend
Qatar
Posts 3,531
Thank you very muchYes - thumbs up
MrAndersen
Posts 226
The bug has been identified and we are working on solution. Test version is expected next week and I will keep you posted on when the fix is going to roll out.
/Thomas
Sweden
Posts 357
Silver Member
Martin replied on Thu, Dec 6 2018 2:25 PM
Hi Tomas,
Great. Looking forward to get the fix before christmasSmile
Best Regards
mr_anders_son
sweden
Posts 1,710
New software out tonight!
BeoVision Haermony 65"...BeoLab 28 Anthracite....BeoLab 17 as REAR....BV10-32....BC6-26....Beosound 9000....Beosound 1 New York edt....Beogram 4002....Beoplay Emerge....Beoplay M5....Beoplay M3....Beoremote Halo....BeoRemote One BT....Beo6....Beo4....Beo4 Cinema....BeoLink 7000....Serene....H95 Black LTD....H9i Rimowa....6 x H6....Form 1....U70...
Sweden
Posts 357
Silver Member
Martin replied on Wed, Dec 12 2018 4:56 AM
Hi Tomas,
Great work! I have already tried the new software and everything works perfect.
You made the fix very fast😊.
I wish you and the team at B&O a Merry Christmas
Thanks again that you responded so fast on the Eclipse software-bug.
Best Regards
Sweden
tigerisak
Posts 124
tigerisak replied on Wed, Dec 12 2018 7:20 AM
No new SW update for me.
MrAndersen
Posts 226
Hi all
This is only out for beta users but will be rolled out to everyone once we have verified. Credit goes to the vision team for moving fast on this, I'm only the messenger :)
I hope we will have it out to everyone soon.
Thank you for your patience
Thomas
Aussie Michael
Melbourne, AU
Posts 3,730
MrAndersen:
Hi all
Thomas
Well done vision team
Page 1 of 1 (26 items) | RSS
