Hi all I have recently masterlinked my house all together which involves
Kitchen. Bv7-32 as video master
Lounge. Beosound 9000+ beolab 8000 as audio master
Conservatory.bv7-32 as slave
Bed 1. Bv6-26 as slave
Bed 2 bv7/32 as slave
My problem being I cannot get the beosound 9000 to play on the video master. It works on everything else (all slave tvs). I have putthe master in option 6 and it works fine but when input it back in option 1 it stops working. Any help appreciated. Thanks
You have it in Vidoe Option 1 so it will only pull video sources. Put the Video Master in Video Option 2 and that should solve your problem
Ok thank you I shall try that thanks
