Hi guys, I was wondering if someone please could tell me which built software is the latest for BV10-46. Thank you very much. Take care
LOEWE bild 5.55 OLED + AppleTV; BS4; BL9; BL8000 MKII all black
Hi hotknife,
my BV 10 was updated in August to build 227. I assume this is still the actual software.
/Räuber
Raeuber:Hi hotknife, my BV 10 was updated in August to build 227. I assume this is still the actual software. /Räuber
Raeuber:Hi Gregory, the clouding issue was reduced after one of the first updates in 2010. With build 227 only a problem with the channel lists was solved. /Räuber
Which build is now - 2014 - the latest?
Has anyone got a list of solved issues/updates in the different builds?
