Hello.
Having just upgraded to Sky Q, I was trying to install using HDMI 1 so we can use 4K, however I’m not having any luck. The TV was installed by B&O, and they only used HDMI ports 2, 3 and 4.
No matter what I plug into HDMI 1 I get no picture.
Any ideas?
Thank you.
I can’t get that far.
Works on HDMI 2, but won’t go 4K as not a supported port.
If if I plug into HDMI 1, I just get a black screen. I can’t change the res.
Pat:8/10 mbits setting is in the Sky Q box itself - make sure that the HDMI lead is the correct one. TV doesn’t accept 10 mbits, it has to be 8.
Thanks, but can’t change to 8 bit until the Sky box recognises that it is plugged into a 4k output, but when I do plug it in, to a 4K output I just get a black screen.
The only res settings I get currently are up to 1080p
Got it working.
All HDMI sockets failed in the end, but I gave the TV 5 minutes unplugged and everything came back to life.
Aussie Michael: But I thought 1-4 do 4 K since that update a while back. Will have to check the FAQs
They are all 4K, but only HDMI1 has HDCP 2.2, which Sky Q needs. Thanks.
Millemissen:There is a tv - and there is a BV.
Yes - glad you saw it.....the picture is gone now! Why, I don’t know?
