Hi everyone,
I just took delivery of a BV7-40 Mk6. Tested the unit before picking it up - all ok. Blu ray player worked perfectly.
Got it home and it has obviously reset all of its settings. Now when I load and play a Blu ray disc I have sound but no picture at all. HDMI on the back is connected to HDMI D. Am I missing something really simple here? Are there other connections or settings I need to deal with, or would there be region code issues?
Regards,
David
First up, disconnect the TV from the mains, take out the HDMI and give it a blow out with compressed air or a lungful of breath! One speck of dirt can wreak havoc.
If that doesn't work, turn off the TV, wait a minute, unplug the HDMI, turn on the TV, then reset the TV to default. Then, turn off the TV at the mains, wait a minute, plug the HDMI back in, then turn on at the mains.
If that doesn't work, power down at the mains, wait a minute, turn on, reset to default, turn off, power down at the mains, wait a minute, turn on again and see if it works.
The 'Internal' Blu-Ray is actually treated as a 'Third Party' by the TV in many ways... as if it was a Blu-Ray Player sitting on a cabinet next to it. The TV could just be having a bit of a wobble recognising it, and most times a slap round the face with a wet haddock in the form of resets usually does the trick.
Lee
