Hi!
My bv 10-46 just arrived and the "soap opera" effect I was afraid off is there.
Some of you mentioned about "movie mode" which should be off but I cannot find it in settings.
Can you please help me?
Thanks!
Try pressing MENU on the remote, place the cursor on OPTIONS and press RED and then GO (within 3 seconds after you pressed RED). You should now be in the "Customer service menu". Go into "Adjustments" and you will find "Film mode". Be careful with the Servce menu – don't touch anything unnecessary!
If you have the new Beo4 with joystick just press the joystick instead of "GO".
Magnus
Liviu_o
please tell me if there is a difference. I`m asking, because on Friday I`ll pick up my new BV10-46. I thought the problem was elimined?
LOEWE bild 5.55 OLED + AppleTV; BS4; BL9; BL8000 MKII all black
I saw 2 movies....one was with soap opera image , the other not.
Don't know what to say...the one with soap opera was 1080p.
I'll check the other.
Maybe HD has this effect.
L
I went in service menu and turned off movie mode ( in picture adjustments). Now the "soap opera" effect went away.
Thanks very much!
Firstly I want to thanks Magnus for his advice!!!!
Rauber......I tried to explain it: image like in south american telenovelas, like the movie is a documentary....filmed by a friend with a hd camera.....etc
