BeoRemote One and BV7
Razlaw
Posts 4,345
Razlaw Posted: Wed, Dec 12 2018 3:34 AM
I have a new BeoRemote One that I have been trying to program. I have working fine with a Core. I also have it working to control a BV7 along with a BS5 and BS3000 that are connected by MasterLink.
My problem is that when in Beo 4 Audio mode if I press the music button, it always shows Radio and starts the Radio. I never listen to radio and do not have an antenna connected to the BS 3000 so all I hear is static. I would like it to start CD or NetMusic or NetRadio when I select music.
I have gone through the menus multiple times. When I go into the select sources menu radio is unchecked. I have checked and unchecked it repeatedly and yet it still shows up in the music source list. I have also gone in to the move menu. There it is not listed so I can not move it.
Is there anything I can do so that pressing music will give a source that works as opposed to radio?
Thanks!
Razlaw
Posts 4,345
Razlaw replied on Wed, Dec 12 2018 3:58 AM
Problem solved. Had remote set for Beo 4, needed it set for Beo AV due to tv being in option 6.
Page 1 of 1 (2 items) | RSS
