Bonjour,
Je crois préférable de poser ma question ici tant le revendeur B&O auquel je m'étais adressé pour l'achat d'un TV B&O Avant 55 est totalement sourd à mes demandes (refuse même d'assurer le SAV!). Bref.
La question de savoir s'il est possible d'appairer un casque audio bluetooth avec le TV, de manière à pouvoir écouter le son sans inonder toute la maison avec le son des enceintes? Je n'ai rien trouvé à ce sujet dans le mode d'emploi...ce qui me laisse peu d'espoir.
On ne sait jamais; si vous avez des pistes.
Bonjour macmaniak,
Sorry for replying in English.
You can add any bluetooth transmitter that has a "press to pair" button fitted by using this cable into any spare PL socket on the Avant:-
https://soundsheavenly.com/televisions/32-389-headphone-adapter-for-beoplay-v1-beovision-1112avant-rj45-powerlink-to-minijack.html#/9-length-18m
This can then pair to Beoplay bluetooth headphones, or any other brand of wireless headphones. You can also use this cable to give a wired connection to a set of headphones if you prefer.
Kind regards, Steve.
Steve.
www.soundsheavenly.com
Hello,
No matter to answer in english.
Thank for the advice, but if I understand well this cable need to be connected to a bluetooth transmitter in addition.
So, after having look for one through the web, I've found this model https://www.boulanger.com/ref/275472?xtor=SEC-2661-GOO&xts=171153&origin=pla&kwd=&gclid=EAIaIQobChMIy4De59Si3wIVBojVCh0IDgsDEAQYBCABEgJKHPD_BwE&gclsrc=aw.ds, which be connected on standard output audio signal. Won't this one work? In fact I don't know if the Beovision Avant, has some output connectors like those on the photo.
In the other hand, I was also wondering how this bluetooth transmission could run: I wouldn't like to have to get up from the cough to go behind the Beovision and connect the transmitter each time I want to ear the sound through my headphones. That means that I expect that the transmitter is all the time connected, and when I would like to use the headphones, I only should have to select, with the remote control of the Beovision, the correct sound output, which is where the transmitter is connected. Is this way possible?
Thanks again.
The device that you found is a receiver, you need a transmitter instead to connect to the headphones, so this will not work. You don't need to connect a transmitter each time you wish to use headphones, you can use the Speaker Group setting in the TV menu to turn the headphone on and off from the B&O remote control.
Very nice Steve,
Thank you very much for your answer (even if it very delayed).
I keep in my mind all your advices.
Sorry for the delay!
