HiI want to find the most simple way to replace a Beosound 2300 with a bluetooth adaptor. What can I choose?
I want to find a active version of the Hall Audio 2x8 to passive speakers. So simple as that. And I don't want to change the cables, so therefore I want to use the exiting powerlink mk3 din cables.
There must be a more simple way than a Beosound Essence, there must be a Hall Audio 2x8 "active speakers version".
Chromecast - but then I cannot use the powerlink cables?
So i put them direct into the line in? Two chromecasts? And how do I then play them together?
You'll need a Beolab 2 adaptor with a PL-Y splitter. The BL2 adaptor will allow you to turn the PL cable into RCA as well as trigger the speakers on. From there just connect your source to the cable and away you go. I'm sure Steve from Sounds Heavenly can provide you with it.
Ah, you know... A little B&O here, a little there
BeoMegaMan:You'll need a Beolab 2 adaptor with a PL-Y splitter. The BL2 adaptor will allow you to turn the PL cable into RCA as well as trigger the speakers on. From there just connect your source to the cable and away you go. I'm sure Steve from Sounds Heavenly can provide you with it. Ah, you know... A little B&O here, a little there
Thanks - but I don't like a Beolab 2. But could I use two chromecast audio and the connected to the line in RCA? But how do I trigger the speakers on?
Master123456789:Thanks - but I don't like a Beolab 2. But could I use two chromecast audio and the connected to the line in RCA? But how do I trigger the speakers on?
Thanks BeoMegaMan,
Yes, I can help with the trigger cable to activate the speakers into Powerlink mode to allow them to be used with a Chromecast Audio via the existing Powerlink cables. As Chromecast Audio has a 3.5mm socket fitted, please use this trigger cable and adapter to link to the existing Powerlink cable:-
Trigger cable: https://soundsheavenly.com/line-in-connection/102-438-minijack-to-beolab-2-7-10-2500-powered-trigger-kit.html#/2-length-1m
Adapter: https://soundsheavenly.com/bang-olufsen/148-powerlink-compatible-barrel-adapter-for-extending-cables.html
If the speakers each have separate Powerlink cables (ie. they are not daisy-chained) then please also add this Splitter to link the two cables together:-
https://soundsheavenly.com/bang-olufsen/26-129-powerlink-compatible-splitter-doubler-2-fully-wired-powerlink-compatible-sockets.html#/20-length-02m
Kind regards, Steve.
Steve.
www.soundsheavenly.com
