Which Music Streaming Service would best suit these needs?
This post has 29 Replies | 2 Followers
LR2015
Posts 81
LR2015 Posted: Sat, Dec 15 2018 7:36 PM
I'm a complete newcomer to Music Streaming Services (MSS), so would appreciate any help and guidance please.
I'm not sure if there is a 'best' solution (for me) but if we base it on a user/family with only Apple devices (iPhone, iPad, Mac etc) and only B&O speakers, is there a MSS which integrates best? Sound quality needs to be good, so is there a MSS best for this?
I've had a quick look on Google and currently it's a choice between Apple Music and Spotify. Spotify seems to get slightly better reviews because of it's bigger catalogue, but Apple gets better reviews for sound quality (AAC?). I'm thinking Apple to keep things easy simply because we are a family of Apple-device users. Tidal is apparently the best for sound quality, but falls short (by a long way) for it's much smaller catalogue.
There's just too much to read and take in on the internet, especially with the addition of Airplay 2, so thought it best to ask on here!
Cheers!
leosgonewild
Helsinki, Finland
Posts 2,373
I would go with Apple Music in your case. Wink
LR2015
Posts 81
LR2015 replied on Sat, Dec 15 2018 7:59 PM
leosgonewild:
Yeah, it's looking that way Smile The 3 month free trial is tempting me.!
Do you have to Airplay the music to a B&O speaker like for example a BS1or2? And does Airplay sound as good as having something like Deezer built into the speaker? This is the bit I get confused with!
Cheers
Jon
Hampshire, United Kingdom
Posts 241
Jon replied on Sat, Dec 15 2018 8:07 PM
LR2015:
Yeah, it's looking that way The 3 month free trial is tempting me.!
Cheers
I’m in the exact same position as you (all Apple + B&O) and Apple Music works best for me because I prefer how Apple Music manages your library. Spotify and AM will basically have the same library for most people, but I’ve got music that doesn’t exist in any streaming service and Apple Music is the only one that lets me upload it myself and edit the metadata to add album art etc. Obviously this is personal preference though.
The AirPlay protocol is lossless so there’s no difference other than the actual audio files between Deezer + AM so you’ll be fine on the audio quality front unless you went for Deezer HiFi.
Aussie Michael
Melbourne, AU
Posts 3,730
This might be a good clip for you to watch
https://youtu.be/shvURl_av0s
I myself only have apple devices at home and I use deezer.
I used deezer because it was inbuilt with the Avant but it never worked that well (slow) so I still kept deezer. I use it on my iPhone at gym and when I run.
I can either use deezer built in on any of my speakers or I can just use airplay.
If you like the Apple Music you can use AirPlay. I don’t think sonically there will be much different between inbuilt and streaming from your phone. The only main real difference is that you always have to use a device with airplay as opposed to walking up and tapping your device when the service is in built.
Jeff
USA
Posts 3,793
Silver Member
Jeff replied on Sat, Dec 15 2018 8:16 PM
First, beware of casual comments that this streaming service sounds better than that one, it is extremely difficult to impossible to tell unless the differences are huge by doing a non-level matched, sighted test (where compare say A and B but know which is which while you're listening). It's very hard to level match to within 0.1 dB which is required, as the human ear perceives small differences in loudness as quality differences rather than loudness differences. So, take any opinions of "I compared Streaming Service with CD and CD was much better" with a huge grain of salt. Take them for what they are, a person's opinion, including the following! Smile
I personally use Spotify Premium, running at 360kbs. I find the sound quality impossible to tell from CD even without level matching. Plus I really like the depth of the music catalog Spotify has, the interface is easy to use, and the radio channels are great. I have one I started off with years ago, a jazz one based off of a Grant Green album. By hitting the thumbs up and down buttons over time, it has become wonderfully adapted to my tastes. They also have various jazz playlists they've recommended to me based on that which have been spot on.
As for quality, once early on I was listening to the album "Mingus: Ah Um" specifically to the song "Goodbye Pork Pie Hat." I was certain I heard distortion on the slow, solo saxophone, so I put headphones on to get a closer listen. Not distortion, but the sound of air moving through the very close miked and softly played sax, it's there on my CD of it as well. So, thought I had a "gotcha" moment for the encoding, but it was accurately reproducing a very low level sound.
Anyway, I'm quite happy with Spotify, your mileage may vary of course, and I'm sure you'll get other opinions, pro and con. Hope you find one you enjoy and are happy with. BTW, I stream Spotify to an Auralic Aries Mini, which replaced a balky Playmaker, using an iPad or iPhone depending.
Jeff
AnalogPlanet
Vienna, Austria
Posts 678
B&O app for some reason pushes Deezer as „Music“ source even if you‘re logged out of Deezer and logged into Spotify...Obviously not even having an option to have Apple Music in B&O app as music source...so keep that in mind if you want to use the app as a main controller.
Aussie Michael
Melbourne, AU
Posts 3,730
Spotify is good too.
I would have gone Spotify but I don’t think u could use that in built with b&o at that time.
I think you did a good thing with going with the Aries mini Jeff 👍🏻
Millemissen
Flensborg, Denmark
Posts 14,680
Like Jeff, I go for Spotify (Premium) too. (Also not sure that I would pay extra, if there were a higher quality version there).
Sure Deezer is better integrated in the B&O NL-ecosystem - but Spotify does integrate pretty well also.
The main reason I go for Spotify is, that is the only way to have gapless playback (important to me, to others not).
Even if I do use Apple devices, I did not go for Apple Music. You can only AirPlay from there - it is much too restricted.
Jeff
USA
Posts 3,793
Silver Member
Jeff replied on Sat, Dec 15 2018 11:53 PM
Good point, gapless playback is important to me too, but I had forgotten about it with other streaming services.
Jeff
LR2015
Posts 81
LR2015 replied on Sun, Dec 16 2018 8:43 AM
Cheers guys - that's the kind of replies I was hoping for!
Interesting Jeff re difficulty in noticing quality differences between streaming services - I'm glad you mentioned this as this was my main concern. It makes sense what you say. Thank you
I forgot to mention - recently just installed an Apple TV 4K onto my BV11 and liked the idea that the ATV now has a Apple Music App. Sorry to mention sound quality again.. but would the sound quality be better through the ATV Music app (obviously the using Apple Music Streaming Service) than with say Spotify > Airplay > BV11? I should also note my BV11 is connected to a pair of Beolab 9's which I think are a great speaker so eager to get the most out of them!
Spotify's Gapless Playback is cool. I can't believe the other MSS don't offer this, yet!
I tried the in-built Deezer when I first got my BV11. It was sooooo slowwwww. So won't be going Deezer. It's still a toss up between AM and Spot - luckily both are the same price for family sharing.
Thanks again everyone!
Sandyb
Posts 2,186
Sandyb replied on Sun, Dec 16 2018 10:35 AM
I wouldn't worry too much about sound quality between the various streaming services.
There are some with a very sensitive ear who find small differences between a good stream and a CD - for some music i know very well, i do find the CD can be a touch richer, but on balance the stream is still very good. For the 30-50 records that in that category, i have a vinyl version if i really want a serious listen / more focussed experience.
By and large the other posters are correct, Spotify, Apple Music, Deezer are pretty much exactly the same re quality. I use Tidal Hifi/Masters for the record - even though that's more for mobile purposes / laptop listening with headphones, their Apple tv app is pretty good.
Deezer don't have a native Apple TV app.
Beyond sound quality, consider how you are going to stream - using a native Apple TV app primarily, or using an iOS device?
I ask because while Apple Music, Tidal, and i assume Spotify have native Apple TV apps, navigating, searching and choosing music is still a bit clunky on the TV / Apple TV.
Anyway, just my thoughts - usability / convenience can be just as important as quality, especially as the streams are of similar standard.
Only you know how sensitive (over sensitive?!? like me!) you are.
Sweden
Posts 357
Silver Member
Martin replied on Sun, Dec 16 2018 10:45 AM
I use Deezer Hifi with my Eclipse. The sound is very good. I have tried SPOTIFY connect also with Eclipse but the sound is rubbish.
So if You want best sound quality (and I can hear the difference) then use Deezer Hifi Or Tidal Hifi. I think it is very convenient using the B&O app for everything when using Deezer Hifi.
Best Regards
NEW! Beovision Eclipse 65 2nd generation (G1) with floorstand (from STB Brackets), Beolab 50 front, Beolab 3 rear, 2 x Beoplay A6 linkrooms, 2xBeoremote one BT, Beosound 9000 Mark III (sw 3.4), Beosound 5 (for DLNA only),  Philips Hue (all lights in the home), Oppo UDP-203, Apple TV 4K (2021 model). Beoremote HALO, 3xBeoplay Charging pad, Beoplay M5
mbolo01
Louannec - France
Posts 2,035
mbolo01 replied on Sun, Dec 16 2018 11:11 AM
I’ve had Deezer HiFi for 1y and to be perfectly honest, moving back to regular Deezer does not hurt. I may not have the proper listening environment deserving 10€/ month more to enjoy higher quality .... or my ears are too old to really hear the difference
koning
holland
Posts 4,220
koning replied on Sun, Dec 16 2018 11:12 AM
Many older albums on deezer are lossyfiles.
Millemissen
Flensborg, Denmark
Posts 14,680
LR2015:
If you have no other B&O/NL devices it all should come down to which UI you like most - unless you are like Martin and would claim to hear a difference between a 360 stream and a losless.
You will have to use AirPlay from the app /the service in favour.
However, if you have (or plan to have) an NL device in the setup, you should try Deezer (and do try out the loslees version too to be sure) - that could make things easier.
There should be no problem in trying out these different options, since you can test for free.
As noted, I went for - and stick to - Spotify Premium....but I never AirPlay (to my ATV’s) from there anyway, I use the Connect feature in my NL devices.
From there i simply joun in on my BV’s.....where my speakers are connected.
Try it out for yourself - then you will know, which one fits you (and the family) best.
tph
Denmark
Posts 161
tph replied on Sun, Dec 16 2018 12:32 PM
LR2015:
Apple Music definitely has gapless playback.
— Tuomas | Bang & Olufsen | Bang & Olufsen Create
LR2015
Posts 81
LR2015 replied on Sun, Dec 16 2018 2:39 PM
Sandyb:
Thanks for reply Sandy. I don't think Spotify has an ATV app yet. On the BV11 (with ATV & BL9's) I would probably use / try the Apple Music app within the ATV. If i buy a separate wireless speaker (like a BS1/2 Edge etc) then I presume I would have to stream via Airplay from my iPhone SE.
LR2015
Posts 81
LR2015 replied on Sun, Dec 16 2018 2:46 PM
Millemissen:
Thanks MM. What's a 'NL' out of interest? Also, is 'Connect' an alternative to AirPlay?
Cheers guys... bear with me... I'm learning Big Smile
Sandyb
Posts 2,186
Sandyb replied on Sun, Dec 16 2018 2:47 PM
Indeed- if you have music playing on the Apple TV, then other devices like a BS1 / Edge can join in (using the app or physically tapping them).
Alternatively if you are streaming Apple Music to an Edge for example, you can join the TV setup using your BV11 remote.
The only minor wrinkle with the B&O app is that if you are AirPlaying from an iOS device to multiple products, the B&O app doesn’t see it as a multi room session. A minor issue to me though.
LR2015
Posts 81
LR2015 replied on Sun, Dec 16 2018 3:01 PM
Sandyb:
Brill - thank you.
Just thinking out loud...and spare funds allowing.. I would like to get to - 1 speaker (possibly BS/2 or M5) in the kitchen, and then another speaker at the back of the living room (possibly A9 or Edge). Then maybe something like a BS1 or M5 in our bedroom upstairs. The BV11 (with BL9s) are at the front of the living room (quite a large room due to being an awkward L-shape). The kitchen speaker would get most of the use - unfortunately an A9 or Edge is just too big and awkward for this space. I hadn't thought of this before but... the missus would need full use of the speakers too - she also would stream through an iPhone SE and I'd add her onto whichever Music Streaming Service I decide on. We also listen to radio a lot so Tunein would get some use (I've got the Tunein app on my iPhone). I *think* I also read some good Google reviews of a radio station within Apple Music - Beats 1?
chartz
Burgundy, France
Posts 4,171
chartz replied on Sun, Dec 16 2018 3:06 PM
I do use Spotify premium but it’s for casual listening (car, dancing).
Quality is just not there. Compression is severely heard - yes it’s 320 kb/s - no stereo image, no depth, bland sound. Look elsewhere if you want quality.
My CDs and vinyl are much better. In France, Qobuz has 16/44 and 24/96 and that sounds good of course.
Jacques
Sandyb
Posts 2,186
Sandyb replied on Sun, Dec 16 2018 4:02 PM
Beats 1 has been a success up to a point i believe, but it does focus quite a bit on modern r'n'b and hip hop, so if that's not always going to be your thing, it may not be a mainstay.
I'd draw your attention to the recent (i believe) update that allows you Beoremote 1 (that you use with the BV11) to have some control over a BS2, A9 etc.  It's limited this far to usual playback controls, but it also nice to be able to select from one of your TuneIn favourite lists - they're listed on the remote screen.
I have an A9 in my bedroom where there is also an Avant BV, so the remote is usually close by - and the capability described above i have certainly found useful, at least for radio. For music it's not much use beyond play/pause/ skip/ volume. Anyway, worth a mention.
Sandyb
Posts 2,186
Millemissen
Flensborg, Denmark
Posts 14,680
LR2015:
Oh, sorry - NL is NetworkLink, which is the native, built in multiroom protocol of B&O.
When we say ‘Join in’, we mean we connect from one (NL-)device to what is playing on another and vice versa (using the Bang & Olufsen app, the physical button on the device or a BeoRemote One).
Your BV11 is a NL device (if set up correctly) and you can join in there to what is playing on whatever other (NL) device you buy e.g. from an M5....
TuneIn is built in to all the NL audiosystems - and can therefore be used independently - no need for AirPlaying there.
(Your BV11 has a Netradio service too - which you could also join in to from e.g. the M5...).
Spotify uses (for the Premiun version) as service, where you control the stream, but this is fetched from the device itself = does not use a direct wifi connection between say an iPad and the M5 - the iPad can be used for something else, once the stream is initiated....or be turned off.
Note: some of the NL devices do not support Spotify Connect.
Feel free to ask again.
Millemissen
Flensborg, Denmark
Posts 14,680
tph:
LR2015:
Would be fine if so.
However, that is what I always have learnt.
I googled a recent article from Macworld (february 2018) - this is what I read:
Gapless playback and crossfade options are common to music apps like Spotify and even iTunes, but absent on the Apple Music app.’.
As I am not an Apple Music user, I am not able to test this.
tph
Denmark
Posts 161
tph replied on Sun, Dec 16 2018 6:05 PM
Millemissen:
I am, and have tested. There is no option for gapless playback because it is always on – this goes all the way back to 2006 and the traditional iPods Smile
LR2015
Posts 81
LR2015 replied on Sun, Dec 16 2018 8:33 PM
Sandyb:
Thanks again Sandy. I don't mind a bit of r'n'b as long as it's not tooooo cheesy Smile Getting bit old for this gangsta rap stuff!
Cheers
LR2015
Posts 81
LR2015 replied on Sun, Dec 16 2018 8:36 PM
Millemissen:
Ah, gotcha! Thanks MM Yes - thumbs up
Millemissen
Flensborg, Denmark
Posts 14,680
tph:
Millemissen:
Thanks for testing - good to know 👍
Page 1 of 1 (30 items) | RSS
