S45-2 and S80 gluing ?
This post has 5 Replies | 0 Followers
John
Yorkshire England
Posts 104
John Posted: Wed, Nov 21 2012 9:32 PM
I have a pair of S45-2 and a pair of S80. I understand the magnets on the S45-2  woofers should be reglued before they move, should the S80s also be glued ? I presume one would not recomend hot glue gun? would an Epoxi Resin such as Araldite be Ok. Or what suitable glue is available in England?
   John.
Søren Hammer
Denmark
Posts 953
Standard twin-component epoxy should do just fine - it is to be applied where the magnet (the black thing that goes around the back side) meets the back piece of the speaker.
Vinyl records, cassettes, open reel, valve amplifiers and film photography.
John
Yorkshire England
Posts 104
John replied on Wed, Nov 21 2012 10:41 PM
Thank you Soren, I will get S45-2 done. Anyone know if the woofers in the S80 are at risk and also need gluing ?
  John.
Dillen
Copenhagen / Denmark
Posts 13,191
Dillen replied on Wed, Nov 21 2012 10:46 PM
No risk so far with the Beovox S80.
John
Yorkshire England
Posts 104
John replied on Thu, Nov 22 2012 11:13 PM
Good to hear that.
Thank you, Martin.
Orava
Finland
Posts 991
Orava replied on Fri, Nov 23 2012 6:49 AM
Søren Hammer:
Speaker body is essential to glue also, if Søren means back plate by "back piece", as back plate can move with magnet if glueing breaks between magnet and speaker body.
Page 1 of 1 (6 items) | RSS
