TX2 Tonearm Movement Problem
This post has 1 Reply | 2 Followers
clamping
Posts 1
clamping Posted: Tue, Dec 18 2018 3:23 PM
I apologize if this has been covered, but I can't seem to find it in searches.
My beloved TX2 started sounding 'off'-- I opened the lid and noticed the tonearm was not at 90 degrees, I pressed stop, it lifted and went back to 90 degrees. When I press play, it goes to the start of the record as normal, but does the same thing.
I read that this is usually due to a sensor bulb going out (where is that one on this model?-- the only bulb I can find is in the left rear, though it looks like there's some sort of bulb housing under the tonearm (if this is so, how do I lift it up to access it?)).
However, the left/right/lift/play buttons have stopped working as well, I don't hear anything when I press them and they no longer do anything.
Is this a sensor issue, or is there a motor that has died? There is only one turntable repair place in town and if I can't do the repair myself, I'd at least like to know what the repair might involve.
Dillen
Copenhagen / Denmark
Posts 13,191
Dillen replied on Tue, Dec 18 2018 9:43 PM
The tracking lamp is inside the carriage housing.
But check the belt for the servo motor - and the servo motor itself.
Page 1 of 1 (2 items) | RSS
