Suitable cross over freq on lab2?
Mdjolly1973
Posts 51
Mdjolly1973 Posted: Wed, Nov 21 2012 10:15 PM
Hi
I have a beolab 2 in a V1 tv 5.1 set up,i cant quite work out the 'ideal' crossover frequency -i have a range from 120hz down to 20hz-can someone explain?
Confused.com
Mdjolly1973
Posts 51
Any advice on this?
DMacri
United States
Posts 881
DMacri replied on Sat, Nov 24 2012 8:20 PM
We'll need to know what other speakers you are using, especially for the center channel if you watch a lot of movies. The reason is there is a lot of activity in the center channel, so you should really make sure you have a good blend there. I believe a good starting point is to select a frequency one octave higher than the lowest frequency your center channel can handle adequately. That way, you have a good transition between the speakers without having the Lab 2 call too much attention to itself or creating too high a level of distortion. The higher the frequency from the subwoofer, the easier it is to locate as the source. You should be fooled into believing the sound is really coming from the center speaker.
Dom
2x BeoSystem 3, BeoSystem 5000, BeoSystem 6500, 2x BeoMaster 7000, 2 pair of BeoLab Penta mk2, AV 7000, Beolab 4000, BeoSound 4000, Playmaker, BeoLab 2500, S-45, S-45.2, RL-140, CX-50, C-75, 3x CX-100, 3x MCL2 link rooms, 3x Beolab 2000, M3, P2, Earset, A8 earphones, A3, 2x 4001 relay, H3, H3 ANC, H6, 2014 Audi S5 with B&O sound, and ambio
Mdjolly1973
Posts 51
Cheers Dmacri
Im running a 40" v1 with a pair of beolab 2's at the front and a pair of rear beolab 2's along with the lab 2 mainly listening to a mix of movies and music streamed via apple tv......
Mdjolly1973
Posts 51
Oh and centre channel is the V1
DMacri
United States
Posts 881
DMacri replied on Sun, Nov 25 2012 12:51 PM
I thought the Beolab 2 was the subwoofer. Anyway, the V1 as the center channel will help. It has a specified frequency range starting at 85 Hz at the low end, so you would have to set the crossover frequency fairly high to get a smooth blend, but it might be too high and cause localization issues. Based on that, I would choose a crossover around 100 Hz and adjust slightly up and down until you are satisfied with the sound.
Dom
Page 1 of 1 (6 items) | RSS
