steve1977:The B&O web-site states that it’s possible to distribute an airplay stream within an NL network. I tried, but failed.
Did you set the right option in the configuation (settings/beolink/sound synchro, mark: "Enable multiroom for Airplay")
Maybe this also will help
https://www.dropbox.com/s/3jorhd6sgg4n8mh/Airplay_2_handout_v1.0.2.pdf?dl=0
Distribution of an AP stream in a NL network has been possible for quite a while now.
My network is pure B&O - personally I prefer the NL distribution of AP and use that from time to time, when streaming from certain apps .
For someone with one or more non B&O AP2 capable devices e.g an ATV4 or a newer Sonos thingy, that he/she also wants to use for multiroom distribution, it may be better to use the AP2 distribution instead of the NL distribution. The same goes for those, who use Apple Music for streaming music.
steve1977: Do you have experience on my follow-up question? Can i stream to 2+ devices via AP2 and then distribute to more devices? My question sounds complex. what i’m trying to solve is to have a home with AP2 and AP2/NL devices. Use multi-room for all speakers and still use “tap” to join for B&O devices.
Your question is not that ‘complex’ - and it indeed was answered in the document that I linked to above.
I don’t use or intent to use both at the same time....so I have no personal experience with that.
The only non-B&O AP2 devices I have are the ATV4’s. These are connected to my tv’s.....that are NL compatible. So no real need for it in my case.
However, I have full confidence when Christian Klit (from B&O) warns against using both!
If you try it out, please tell us about your experience - maybe someone else has tried it already.
