Link output connection on BV7 / BS3 - to distribute digital stereo on RF link feed
This post has 0 Replies | 0 Followers
Stefan E
Sweden
Posts 101
Stefan E Posted: Mon, Dec 24 2018 10:24 PM
I would like to check if I anyone can confirm if I can use SCART 1 as a possible output source for a separate link feed that will distribute the same source as the RF link output does. Im thinking about SCART 1 since it´s mentioned that this one should be used use if you would like to record sources on the videomaster and also that this connector work without that the videomaster is on.
My idea is to replace the existing RF Link signal that today only carry MONO sound to connected link TV´s with a RF signal that distribute the sound via NICAM stereo.
I today have 3 pcs of DVB-T / analog converters that convert 9 free chances to analog channels with NICAM stereo sound. So I was thinking to use one of the channels to distribute a link feed with stereo sound by using a DVB-T modulator from either the analog signal or via a via a HDMI converter in between.
By doing this I can both have stereo sound directly on all my analog link TV´s and also "release" the ML to distribute second audio source in stereo to other link room.
Stefan
BS3 DVB-HD, BV7-40 MKIII, BC6-26, BC6-23, BV4-50/BS2, BS5, BS9000, BL3500, MLGW, BLGW, PlayMaker, - BS6500, BS4500, LX6000, VX7000, MX5500, VX5000 - Beo6, Beo5, BeoTimex2, Linctonic
Page 1 of 1 (1 items) | RSS
