Can you fit an Apple TV 4K in the rear of an Avant 55 NG?
1990
Posts 521
1990 Posted: Wed, Dec 26 2018 6:48 AM
My parents have bought an Avant 55 NG. I’ll give them a Apple TV 4K to go with it - but can it be installed in the rear or does it need to be hidden in a cabinet?
Aussie Michael
Melbourne, AU
Posts 3,730
No. It’s too thick to fit.
It fits the earlier model.
But even still it’s better not to fit one there because it may overheat anyway.
You can put it in a cabinet or alternatively you can get the bracket from sTB
Or even still what about sticking the bracket you can buy from the Apple store on the back ? You will also need a PUC cable for it too to use it with the beoremote one.
Solidsnake
Posts 143
I had an Avant NG and Apple TV 4K and it fit no problem inside the back of the cabinet.
Page 1 of 1 (3 items) | RSS
