Beocom 6000 MkII registering to MkII Base
This post has 4 Replies | 0 Followers
breuter
Posts 3
breuter Posted: Thu, Dec 27 2018 11:39 AM
Hi
Just bought a pair of ekstra second hand MkII handsets.
Same SW version as my existing ones.
Now trying to register them with my base after opening the base for registration.
I get the error "Failed". Tried this now quiet a few times after resetting the HS again with the same result.
Kind regards
Brian
Guy
Warwickshire
Posts 2,590
Guy replied on Thu, Dec 27 2018 12:00 PM
Good morning and welcome to Beoworld!
You haven't said what type of PSTN base you are trying to register it to.  The old 'pyramid' PSTN base will only accept a maximum of 6 handsets.
Worth having a read of this also, to check compatibility: https://www.beoworld.org/faq_view.asp?id=74
breuter
Posts 3
breuter replied on Fri, Dec 28 2018 6:55 AM
Hi - thanks!
It's a  BeoLine 1113070 Dk base. It's not a pyramid, but a small rectangular box.
Mk II handsets has SW ver. 2.60 of May 5 - 2006. I want to add an additional Mk II handset with the same SW version.
There are 3 Mk II handsets and 2 Mk I handsets on the system.
There are both Mk I and Mk II handsets on the system. Perhaps that limits the number of Mk II handsets?!
I just deregistered and older Mk I handset. That made no difference.
Thanks for getting back to me!
Cheers
Brian
breuter
Posts 3
breuter replied on Fri, Dec 28 2018 8:32 AM
Found th problem!
This bas will register up to 8 handsets.
There was 3 "ghost handset" registered, which I have removed. The registration now went thru.
Cheers
Guy
Warwickshire
Posts 2,590
Guy replied on Fri, Dec 28 2018 9:41 AM
Glad that you got it all working, and thanks for letting us know!
Page 1 of 1 (5 items) | RSS
