I would like to share the following issues I'm facing with my M3 and software 1.3.26290:
The Power Saving mode, newly introduced, puts my M3 in a NO NETWORK status (fixed blue LED) after a while when not used, and the only way I can have it back into the network is a power off/on.
When powered on, the volume of the sound is very high at the very first use post power on, despite the configured volume setting (I think this has happened to M5 users several software versions ago)
Does anyone faces such issues?
Livingroom: BL3, BL11, BV11-46 Kitchen: Beosound 1 GVA, Beocom 2 Bathroom: M3 Homeoffice: M3, Beocom 2 Library: Beosound Emerge, Beocom 6000 Bedroom: M5, Essence remote Travel: Beoplay E8 2.0, Beoplay EQ, Beoplay Earset
I saw the blue light yesterday, but didnt give it much thought.... I just did a power recycle because I coudnt remember what the blue light ment,.. :)
Since its been "white light" but i'll keep an eye on it.
Find me on YouTube : Bang & Olufsen Teknisk Forum : https://www.youtube.com/c/BangOlufsenTekniskForum
Hiort: I have the same fw version, but have not the powersave activated. I think the power consumption in standby is minimal anyway.
If so minimal what is the benefit of this option then? I’ve not seen any description, and it does not seem to behave properly anyway.
baronvejrup: I saw the blue light yesterday, but didnt give it much thought.... I just did a power recycle because I coudnt remember what the blue light ment,.. :) Since its been "white light" but i'll keep an eye on it.
Is Power Saving mode checked on yours? I'm trying to identify if it could be linked to this setting, the only one I changed recently, or if it is linked to something else. I'll see tomorrow anyway if turning Power Saving mode off has changed the behavior.
No Power Saving is not active on my M3
I checked with a tool and power consumption is around 2 - 3 watts in standby.
