Happy new year, but I have a problem: Trying to use the Beovision loudspeakers from my iphone. Should work, according to the manual, where it says that I should get a camcord option in the menu. What I get, though, is just TV, radio, DVD, settings, and TEXT. White nd red RCA are connected to the front panel, with the tele going into my ipone, but there is no sign of the connection working. Has anyone had the same idea?
If you're using a Beo4 to control it:
To add CAMCORD, on the Beo4:
- Press Power and LIST together, the display should read ADD?
- Press GO.
- Press LIST until the display shows CAMCORD. then GO.
- CAMCORD should then be listed under LIST.
Thanks, Guy! I only have the Beovision-specific control with the four buttons on hand right now, so what you are saying is that I need the Beolink 4 to get this setup working?
Best regards
Lennart
Hmmm. Not sure if it will work but I found this in the manual:
Note: While the CamCorder is connected, it will be possible to select CAMCORD via the display sequence - press DISPLAY, use << or >> to find CAMCORD and press GO to select.
There must be a Shift function for that - just don’t remember which.
Millemissen: There must be a Shift function for that - just don’t remember which. MM
Possibly, but no SHIFT button on Beo1 remote: https://www.beoworld.org/prod_details.asp?pid=693
Hence not sure how you'd do it on a BL1000
Yeah, I saw that too, so I ordered a Beolink 4, since this seems to be the only workaround.
You’re right: without the list function, nothing can be done. The 1000 is the best design, but it cannot crack this one. Happy new year!
