Is stereo still a thing? aka. Is one BEOPLAY A9 MKII enough?
This post has 45 Replies | 3 Followers
Millemissen
Flensborg, Denmark
Posts 14,680
toptip:
This is how the Red Lines are hung now. I thought two A9s to replace them may look nice:
They might ‘look nice’, yes.
But why would you want to replace two speakers with two music systems?
toptip
Posts 32
toptip replied on Tue, May 7 2019 9:19 PM
Millemissen:
toptip:
I thought because the A9 is a system and it has an internal equalized crossover, it may have better bass and just better sound than the Red Lines. In the end it is a powerful, tri-amplified speaker.
But again, if it is hanging from the ceiling I may have issues controlling it, especially if it does not have a remote control, so I have to figure out if I can actually use it like I am thinking.
Plus, I think there is something appealing in using BO components in ways they were not intended to be. Take a look at this stack. I disabled the power amps and one half of the (110 +110V) power transformer in the BM6500 (to reduce standby power consumption), it just acts as a remote control receiver to control the BG 5500, the Beocord and the CD player. Those "sources" are then connected to an ARCAM preamp which feeds a SONOS system (both inside the cabinet). The BM is controlled by a (also hidden) Harmony Hub wi-fi remote control system. This allows me to start or stop playing a LP or cassette from an iPhone anywhere and listen to it in any room. (Of course the alternative is to place 8 cassettes in the Philips carousel -- also networked -- and not worry about music the next 10 hours!):
Millemissen
Flensborg, Denmark
Posts 14,680
Sure you can do such things....it may be fun.
You’d end up with two fullblown stereo speakers (in each their enclosure), where you’d have to feed a right respectively a left sound signal into the line-in connections and hope for the speakers to have the same volume level..........and a bunch of functions that you can’t use and have payed for.
Wouldn’t it be more fun to replace the Red Line’s with a set of BL17....if you can feed them with a volume-regulated (as an alternative to PL) output from an x-source 🤔
Or is it that you just like round curves more than rectangular 🤪
toptip
Posts 32
toptip replied on Tue, May 7 2019 10:23 PM
BL18 as in Beolab 18? I have a pair. But I do not think that would be much of an improvement over the Red Lines in the bass department, would they?
moxxey
South West, UK
Posts 5,359
moxxey replied on Wed, May 8 2019 2:28 PM
Aussie Michael:
The A9 will be enough for you and especially in a bedroom.
Mainly I use my BS1.
I've probably replied to this thread, but feeling too rough today to check.
I truly miss my A9. I've owned just about every B&O speaker (bar the BL50 or BL90) and the A9 has consistently blown me away and, no, you don't need 'stereo' to improve the experience.
I sold my A9 to become more portable for a forthcoming move away from the UK. I bought a BS2 which is decent, but not a patch on the A9.
toptip
Posts 32
toptip replied on Thu, May 9 2019 9:38 PM
So I bought a used A9. Before I buy a second one I will try it for some period of time as is. The other thing I thought is mounting it at a 90 degree angle to see how it works in "mono" that way, kin of in a psuedo "d'Appolito" arrangement:
Page 2 of 2 (46 items) < Previous 1 2 | RSS
