As to my previous forum. I rescently got my first beogram with speakers and amp. I ended up going with the Beomaster 3500. Beovox S45’s and a Beogram 8500.
I got the Beogram today, and it is making a grinding noise. It changes as the arm goes down the record and you can hear the noise through the speakers at high volume. If you adjust the arm using the left and right switches it gets to a certian point where it starts making the noise. I removed the platter and it makes the same noise with the platter off.
Note: I have loosened the transport screws
Anyone know what what it is? Wether it’s the suspension needing adjusted or something else?
