Hi all, this is my first post here :)
I have bought 2 Becom 6000 MKII with a Beoline PSTN base (the square black one without any light or indicator).
They were working fine, but since they had phone numbers from the previous owner, I reset the base using 9#9#9*INT as I saw in this site and then I reset also the phones (not sure why)
When I try pairing them again with the base, it is not found, they keep searching but it's not visible to them.
Any idea?
Thanks in advance
Hi and welcome to Beoworld!
If the PSTN base is the large square one (about the size of a CD case) then you have to press and hold the little button on the back for at least 4 seconds to put it in pairing mode.
Then try searching from the handset again.
Ah, I didn’t know that the white plastic thing was a button 😅 but that sounds great!!
I’m not at home until end of the week, so I’ll check that and update the post.
Thanks!!
EXCELLENT!!! Working perfectly fine, many thanks! :)
Great news - thanks for letting us know!
