Alarm on Beosound Moment?
This post has 3 Replies | 0 Followers
laseralex
Posts 240
laseralex Posted: Mon, Jan 7 2019 11:25 AM
The current version of the B&O allows me to set an alarm on the Beosound Moment I have in my bedroom.  However, I can’t seem to figure out how to set the time / time zone.  If I set the alarm for 9am it comes in some time in the afternoon.  Not so useful.
Can anyone one tell me where to set the time / time zone for my Moment is the alarm will work?
Thanks in advance!
-Alex
Sources: 2x Beosound Moment • 4x Beosound Essence Mk II
Speakers: 3x Beolab 8000 • 2x Beolab 6000 • 2x Beolab 3 • 3x Beolab 2
Integrated:  1x Beosound 2 • 1x Beosound Level • 4x BeoPlay M5 • 1x BeoPlay A6
Control:  16x* Essence Remote  • 1x Beoremote Halo
* Yes, really! 🤦‍♂️
mbolo01
Louannec - France
Posts 2,035
mbolo01 replied on Mon, Jan 7 2019 3:52 PM
You have to remove the lid in the back of the SoundHeart to bring the configuration menu on the JukeBox.
From there select Global settings (or something similar to Généralités in my French version).
Make sure the country is the correct one, if not change it, then tap on Date and time at the top of this screen and select automatic.
Hope this works for you
laseralex
Posts 240
This did it.  Thank you!
* Yes, really! 🤦‍♂️
kimhav
Malmo, Sweden
Posts 314
kimhav replied on Tue, Jan 8 2019 8:05 AM
Redundant posting as I didn't see the response...
Page 1 of 1 (4 items) | RSS
