just brought a beosound moment on ebay. Had a great deal half the price of the normal ones being sold on ebay. Anyway to get to the point, i would like to connect it to my beolab 6000 via beosound reciever 1. My question is does the moment transmit wifi to speakers and if so would it work with the beolab receiver 1 without the need of buying a separate transmitter?
Current b and o Products
beosound 5 encore, beolabs 6000, beogram 4500, playmaker mk1
Paul cheacker:just brought a beosound moment on ebay. Had a great deal half the price of the normal ones being sold on ebay. Anyway to get to the point, i would like to connect it to my beolab 6000 via beosound reciever 1. My question is does the moment transmit wifi to speakers and if so would it work with the beolab receiver 1 without the need of buying a separate transmitter? Current b and o Products beosound 5 encore, beolabs 6000, beogram 4500, playmaker mk1
Livingroom: BL3, BL11, BV11-46 Kitchen: Beosound 1 GVA, Beocom 2 Bathroom: M3 Homeoffice: M3, Beocom 2 Library: Beosound Emerge, Beocom 6000 Bedroom: M5, Essence remote Travel: Beoplay E8 2.0, Beoplay EQ, Beoplay Earset
Thats great news one more thing if i then connect a beogram 4500 to the moment would i be able to listen to the music on a beosound 1 in a different room without having the main room beolab 6000 playing at the same time?
This a Network Link (B&O multiroom) feature.
Correct set up, you can indeed listen to a source on the line in of one device (in this case the BeoGram 4500) via another device/the speakers there/the BeoSound 1.........without the speakers of the leading device being active.
However, this has nothing to do with how the speakers are connected - wired or wireless does not matter anything there.
Ok thats prefect news.
Thanks all for your responses and info
