BEOMASTER 1900 and BEOGRAM 1500
wim06
Posts 2
wim06 Posted: Fri, Jan 11 2019 1:51 PM
Hello,
I found my parents' old B&O hifi on the atic, installed it in my home, it works but with some flaws:
- the button Turn33/Stop/Pause45 of the turntable is not working correct. One has to push it several times to make it work.
- the on/off switch of the beomaster gets sometimes stuck (will be broken soon?)
- it seems that one channel is less loud than the other. I have to put the balance 80% on the  weak channel to have an equilibrium
- the bass slider doesn't work
- several lights aren't working
Some questions now :)
- Is it easy to find butons etc for repair (like the bass slider potentiometer)
- Any idea about the turntable button?
- Any idea about the volume problem?
- what is recommended also in prevention on the beomaster 1900? (are there some tutorials somewhere?)
Thanks!!
Wim
wim06
Posts 2
wim06 replied on Fri, Jan 11 2019 1:53 PM
Just for information, I tested it with 2 Klipsch Heresey II speakers of a friend of mine.
But I found on ebay a pair of nice S45 to go along with the rest... :D
Page 1 of 1 (2 items) | RSS
