Beocenter 7700
This post has 2 Replies | 2 Followers
Westglacier
Posts 1
Westglacier Posted: Sun, Jan 13 2019 1:03 AM
When i use the B&O turntable, it occasionally speeds up. I've noticed that the longer it's in use, the more prone to the speed up.Is this something more than needing a new belt?
ProGram
59269 Beckum, Germany
Posts 383
ProGram replied on Sun, Jan 13 2019 8:44 AM
It probably needs some new speed setting trimmers. The problem is with 33 and 45? Or there are bad solder joints. Or the supply voltage (internally) is no longer stable. In any case it will need a set of new capacitors in every section.
solderon29
U.K.West Midlands
Posts 764
solderon29 replied on Sun, Jan 13 2019 12:49 PM
Indeed,as above,but also it's worth checking the turntable motor.The bearings may well have dried out with age,so that as the unit warms up the bearing's free up and the turntable runs faster.
You can download a strobe disc from the 'net,so that you can monitor the speed at start up from cold etc.
Nick
Page 1 of 1 (3 items) | RSS
