BLC NL/ML System log activities
This post has 0 Replies | 0 Followers
kimhav
Malmo, Sweden
Posts 314
kimhav Sad [:(] Posted: Tue, Jan 15 2019 7:09 PM
Got to say that it's not that often that I login and check the BLC regarding the system logging but I do one a while to see what's going on and if there are any errors. So I've noticed now that there are quite a few http errors and just wondering if it's trying to ping external site which isn't available and as well it seems to check for new software version which I've actually disabled. So open for some suggestions and pointers which the below log data might indicate:
Jan 15 20:00:08 (none) BLC[1159]: [info]:BeoNetRemote is asking current status
Jan 15 20:00:08 (none) BLC[1159]: [info]:Using distributed experience for status
Jan 15 20:00:08 (none) BLC[1159]: [info]:Client disconnected. Message: Socket error. Error: Connection reset by peer, ErrorCode: 104 [Notifier.cpp:233]
Jan 15 20:00:08 (none) BLC[1159]: [info]:Dismissing HTTP Response due to errorState [Http.cpp:349]
Jan 15 20:00:19 (none) BLC[1159]: [info]:BeoNetRemote is asking current status
Jan 15 20:00:19 (none) BLC[1159]: [info]:Using distributed experience for status
Jan 15 20:00:30 (none) BLC[1159]: [info]:BeoNetRemote is asking current status
Jan 15 20:00:30 (none) BLC[1159]: [info]:Using distributed experience for status
Jan 15 20:00:33 (none) BLC[1159]: [info]:Looking for a new software...
Jan 15 20:00:33 (none) BLC[1159]: [info]:Checking for software updates...
Jan 15 20:00:33 (none) BLC[1159]: [info]:Update info isAvailable: 0
Jan 15 20:00:33 (none) BLC[1159]: [info]:Update url:
Jan 15 20:00:33 (none) BLC[1159]: [info]:Beoportal sw ver:
Jan 15 20:00:33 (none) BLC[1159]: [info]:No new updates available.
Jan 15 20:00:33 (none) BLC[1159]: [info]:No software updates available
Jan 15 20:00:41 (none) BLC[1159]: [info]:BeoNetRemote is asking current status
Jan 15 20:00:41 (none) BLC[1159]: [info]:Using distributed experience for status
Jan 15 20:00:51 (none) BLC[1159]: [info]:BeoNetRemote is asking current status
Jan 15 20:00:51 (none) BLC[1159]: [info]:Using distributed experience for status
Jan 15 20:00:51 (none) BLC[1159]: [info]:Client disconnected. Message: Socket error. Error: Connection reset by peer, ErrorCode: 104 [Notifier.cpp:233]
Jan 15 20:00:51 (none) BLC[1159]: [info]:Dismissing HTTP Response due to errorState [Http.cpp:349]
Jan 15 20:01:02 (none) BLC[1159]: [info]:BeoNetRemote is asking current status
Jan 15 20:01:02 (none) BLC[1159]: [info]:Using distributed experience for status
Jan 15 20:01:13 (none) BLC[1159]: [info]:BeoNetRemote is asking current status
Jan 15 20:01:13 (none) BLC[1159]: [info]:Using distributed experience for status
Jan 15 20:01:24 (none) BLC[1159]: [info]:BeoNetRemote is asking current status
Jan 15 20:01:24 (none) BLC[1159]: [info]:Using distributed experience for status
Jan 15 20:01:34 (none) BLC[1159]: [info]:BeoNetRemote is asking current status
Jan 15 20:01:34 (none) BLC[1159]: [info]:Using distributed experience for status
Jan 15 20:01:34 (none) BLC[1159]: [info]:Client disconnected. Message: Socket error. Error: Connection reset by peer, ErrorCode: 104 [Notifier.cpp:233]
Jan 15 20:01:34 (none) BLC[1159]: [info]:Dismissing HTTP Response due to errorState [Http.cpp:349]
Jan 15 20:01:34 (none) BLC[1159]: [info]:Client disconnected. Message: Socket error. Error: Broken pipe, ErrorCode: 32 [Notifier.cpp:233]
Jan 15 20:01:45 (none) BLC[1159]: [info]:BeoNetRemote is asking current status
Jan 15 20:01:45 (none) BLC[1159]: [info]:Using distributed experience for status
Jan 15 20:01:56 (none) BLC[1159]: [info]:BeoNetRemote is asking current status
Jan 15 20:01:56 (none) BLC[1159]: [info]:Using distributed experience for status
Jan 15 20:02:07 (none) BLC[1159]: [info]:BeoNetRemote is asking current status
Jan 15 20:02:07 (none) BLC[1159]: [info]:Using distributed experience for status
Jan 15 20:02:07 (none) BLC[1159]: [info]:Client disconnected. Message: Socket error. Error: Connection reset by peer, ErrorCode: 104 [Notifier.cpp:233]
Jan 15 20:02:07 (none) BLC[1159]: [info]:Dismissing HTTP Response due to errorState [Http.cpp:349]
Jan 15 20:02:17 (none) BLC[1159]: [info]:BeoNetRemote is asking current status
Jan 15 20:02:17 (none) BLC[1159]: [info]:Using distributed experience for status
Jan 15 20:02:28 (none) BLC[1159]: [info]:BeoNetRemote is asking current status
Jan 15 20:02:28 (none) BLC[1159]: [info]:Using distributed experience for status
Jan 15 20:02:39 (none) BLC[1159]: [info]:BeoNetRemote is asking current status
Jan 15 20:02:39 (none) BLC[1159]: [info]:Using distributed experience for status
Jan 15 20:02:49 (none) BLC[1159]: [info]:BeoNetRemote is asking current status
Jan 15 20:02:49 (none) BLC[1159]: [info]:Using distributed experience for status
Jan 15 20:02:50 (none) BLC[1159]: [info]:Client disconnected. Message: Socket error. Error: Broken pipe, ErrorCode: 32 [Notifier.cpp:233]
Jan 15 20:02:50 (none) BLC[1159]: [info]:Dismissing HTTP Response due to errorState [Http.cpp:349]
Jan 15 20:03:00 (none) BLC[1159]: [info]:BeoNetRemote is asking current status
Jan 15 20:03:00 (none) BLC[1159]: [info]:Using distributed experience for status
Jan 15 20:03:00 (none) BLC[1159]: [info]:Client disconnected. Message: Socket error. Error: Connection reset by peer, ErrorCode: 104 [Notifier.cpp:233]
Jan 15 20:03:00 (none) BLC[1159]: [info]:Dismissing HTTP Response due to errorState [Http.cpp:349]
Jan 15 20:03:11 (none) BLC[1159]: [info]:BeoNetRemote is asking current status
Jan 15 20:03:11 (none) BLC[1159]: [info]:Using distributed experience for status
Jan 15 20:03:11 (none) BLC[1159]: [info]:Client disconnected. Message: Socket error. Error: Connection reset by peer, ErrorCode: 104 [Notifier.cpp:233]
Jan 15 20:03:11 (none) BLC[1159]: [info]:Dismissing HTTP Response due to errorState [Http.cpp:349]
Jan 15 20:03:21 (none) BLC[1159]: [info]:BeoNetRemote is asking current status
Jan 15 20:03:21 (none) BLC[1159]: [info]:Using distributed experience for status
Jan 15 20:03:33 (none) BLC[1159]: [info]:BeoNetRemote is asking current status
Jan 15 20:03:33 (none) BLC[1159]: [info]:Using distributed experience for status
Page 1 of 1 (1 items) | RSS
