Beovision 8-40 - remote control setting issues
This post has 6 Replies | 0 Followers
pjop
Posts 16
pjop Posted: Sat, Jan 19 2019 9:38 PM
I bought a preowned bv 8-40. It seems like it is configured to work with beo4 joystick version since I can use the arrow keys on my non-joystick version. Can I reset the TV some way to change this setting?
Many thanks!
Millemissen
Flensborg, Denmark
Posts 14,680
No reset needed.
Just call up the menu and navigate using the numbers - means 1 for the first, 2 for the second.
Don’t forget to accept with Go.
Millemissen
Flensborg, Denmark
Posts 14,680
Oh, of course I should have added, that you will have to navigate this way to the Beo4 setup item...
.....where you can change the behaviour of controlling from with to without navi.
Millemissen
Flensborg, Denmark
Posts 14,680
This one
pjop
Posts 16
pjop replied on Sun, Jan 20 2019 1:59 PM
Super, it worked!
Thanks!
pjop
Posts 16
Super, it worked!
Thanks!
pjop
Posts 16
Super, it worked!
Thanks!
Page 1 of 1 (7 items) | RSS
