Beosound 9000 >Beolab 2 In>Beolab 2 Out>Beosound 6000s.
All speakers red when on standby. When 9000 is turned on, the Beolab will briefly power on to green than back to red. When I plug the 6000s directly to the 9000 without the Beolab they work fine.
I searched the forums and a guy who had this issue replaced the board/s on the Beolab 2 at a huge cost, I prefer not to go down this path. Any ideas or suggestions, leaky/blown caps?
Have you checked the Beolab 2 using one of the cables that you used when the Beolab 6000s were working directly on the Beosound? It could just be a faulty cable.
Kind regards, Steve.
Steve.
www.soundsheavenly.com
Yes, I mentioned that already, the 6000s are fine when connected directly.
Thanks, if the same cable was used both times then you can rule out a cable issue, it sounds like a speaker fault.
I have these frequently in for repair.
Apart from a ntc or defective driver it could be the PSU and/or ICE power.
Until recent a complete chassis was available (at the costs more than a secondhand other one).
So fixing means more internal investigation.
