I just bought a preowned BeoVision 8-40 with PUC cables. I’m new to PUC. How does it work?
- Are the schemas for all versions AppleTV the same?
- Which version of beo4 do I have to have (is non-joystick ok)
- Which buttons do I use?
- There are only two alternatives in PUC list. How can I get more to chose from?
The main codes are the same between the different AppleTVs. Some of the later ATVs has commands that the older does not have. Only the B&O dealer can add more PUC codes to your TV.
Beo4 version does not matter.
I dont know exactly the buttons on the Beo4 and how they translate to AppleTV, but main buttons are the arrows up, down , right , left.
Select by pushing in the middle.
Make sure to put the IR-eye on the PUC cord in the middle of the AppleTV front, so it covers the IR receiver.
Livingroom: BL3, BL11, BV11-46 Kitchen: Beosound 1 GVA, Beocom 2 Bathroom: M3 Homeoffice: M3, Beocom 2 Library: Beosound Emerge, Beocom 6000 Bedroom: M5, Essence remote Travel: Beoplay E8 2.0, Beoplay EQ, Beoplay Earset
