Hi guys,
My second post here, so apologies for not contributing elsewhere. I've read a lot the last few days regarding the problems that I have, but so far I haven't found the solution.
Actually I have two issues with my Beogram 6500, and they might sound familiar to you. The first problem is that when the Beogram moves the tone arm to the record, it actually drops the tone arm next to the record. I already found that the actual drop position can be adjusted. However, there is not enough adjustment range, even after adjustment the tone arm still drops next to the record.
The second issue is that the 'sledge' that carries the tone arm does not move when the tone arm had reached its maximum rotation. Thus the record is stuck in the same position. A slight push starts movement of the sledge again and the record continues to play, until the same problem occurs.
What I've checked:
Dom
2x BeoSystem 3, BeoSystem 5000, BeoSystem 6500, 2x BeoMaster 7000, 2 pair of BeoLab Penta mk2, AV 7000, Beolab 4000, BeoSound 4000, Playmaker, BeoLab 2500, S-45, S-45.2, RL-140, CX-50, C-75, 3x CX-100, 3x MCL2 link rooms, 3x Beolab 2000, M3, P2, Earset, A8 earphones, A3, 2x 4001 relay, H3, H3 ANC, H6, 2014 Audi S5 with B&O sound, and ambio
I also think the need for lubrication is a must. There is a section in the service manual pointing out how. The cartridge need more than 1 gram to track correctly. The MMC-2 I have from www.tonabnehmerservice.de have a recommended 1.4 gram for best tracking.
Thanks for the input, but I don't think lubrication is the (main) cause of this. There seems to be some positioning error.
Just to be sure I'll replace the drive belt and see if that does the trick. I just read another topic where it did... I'll keep you posted.
Hi Tsjoechov,
Did you manage to fix your problem. I have a beogram 5005 and the tone arm can be adjusted so that it just (and only just) reaches the edge of the LP. I would like it to go a mm or so further but there is no adjustment left.
The small hook for the carriage wire is about to break off.Martin
Thank you Martin. That would certainly explain what I'm seeing. However I've double checked and the peg does not appear to be about to break. I've taken a photo to show what I see...
Looks fine, I agree.Will the excentric not move the set-down point at all?
Yes it does adjust the setdown point. When the spring is short the setdown is about 4 or 5mm before the record start. At its longest length the setdown is just at the start, but falls of about 1 in 10!
Check that the carriage wire has been fitted correctly;It has a small knot from factory, that needs to sit in a small cutout along the ridge across the cam wheel it has been fitted around.
Dillen: Check that the carriage wire has been fitted correctly;It has a small knot from factory, that needs to sit in a small cutout along the ridge across the cam wheel it has been fitted around. Martin
Adjust the 17cm set down first with the excentric then fine tune the 30cm set down with the quadrant on the pulley'
I no longer have access to the service manuals to enable me to be more specific!
Regards Graham
Thank you all. The knot does appear to be in the correct place. The 17cm put down is similarly sliding off the record even at the extreme of adjustment. Perhaps if I remove and re-thread the cord it may have an effect- is this relatively straightforward?
Has the tonearm been bent or is it off parallel to the sensorarm?Does the carriage sit correctly on its rails?
