I have just got my Beoplay E8 2,0
Initially I was able to add the headphones, but after a while the app lost contact with the headphones.
I removed the E8 from the app and added product again. E8 are found but setup process then got stuck after setting of the earphones name (i kept the default).
Annoying..
Livingroom: BL3, BL11, BV11-46 Kitchen: Beosound 1 GVA, Beocom 2 Bathroom: M3 Homeoffice: M3, Beocom 2 Library: Beosound Emerge, Beocom 6000 Bedroom: M5, Essence remote Travel: Beoplay E8 2.0, Beoplay EQ, Beoplay Earset
Hello @MrAndersen
So after you power on the H5 earphones you have the Tonetouch preset that you load before you turn off them?
Maybe we have a fault product?Because i see many users here with the same problem.
If yes then i have to contact with the support.Pls help to solve it.
Hiort: I have just got my Beoplay E8 2,0 Initially I was able to add the headphones, but after a while the app lost contact with the headphones. I removed the E8 from the app and added product again. E8 are found but setup process then got stuck after setting of the earphones name (i kept the default). Annoying..
I can add that now the app cannot find the E8 at all.....
I am still missing the "Touch to Join" in the product source list for my BV8-40 (BLC converter). And as I have said before it works fine with Beo4. So it should be easy to add in the app for ML productions. I have checked the BLC configuration and here nothing that needs to be selected. So hopefully the Join function will be added.
When we are with BLC (ML products) and the App. Could we please soon get more functionality. Especially browse to next/previous channel group (the right/left browse function) and list function in the app could be used to activate the channel list.
Hi Guys, I just got a new TV, and I wanted to delete my old BV14 from the app, but everytime i click on the product my app crashes, both iOS and Android. Any Idea how to remove it from my list?
Find me on YouTube : Bang & Olufsen Teknisk Forum : https://www.youtube.com/c/BangOlufsenTekniskForum
baronvejrup:Hi Guys, I just got a new TV, and I wanted to delete my old BV14 from the app, but everytime i click on the product my app crashes, both iOS and Android. Any Idea how to remove it from my list?
@MrAndersen
Just noticed that the "black" config screen in the App for my BV14 with the circular volume controle is gone. Gone forever? It was kinda handy in just controlling the volume..
Karel.
Hi Hiort
I know how to remove products, the issue is that the app crashes everytime i click on the BV14 in the remove pane.
So the H5 owners are in B&O's mercy to fix the bug with the tonetouch preset that doesn't remember the last settings,someone said that is over a year like this.
So all the H5 models are affected and for me B&O has to replace with the E6 model that it work as it should.
If not we need to know when they'll fix it because in my eyes they look like they can't.
Sorry if i sound rude but i pay them 250 euros and there are not excuses.
EDIT i sold them and bought the E6 model...I can't stand the sound.
mbolo01:I noticed the following issue: when DLNA/Deezer album/tracks are added to a product play queue through the app, the generated play queue loops even if the loop option is not activated. I can produce this behavior on several products such Core, M3. Even loading a single track loops for ever. Anybody noticed that? BS Moment, BS Core, Beosound Ouverture, BS 1, BL 18, BL 19, BL 8000, A6, M5, M3, A1, H5
Best regards - Dyssegaard
Living room: Beovision Eclipse 55, Beolab 3 / R1 (back), Beolab 2 / R1 (sub), AppleTV 4K. Bedroom: Beovision 11-40, AppleTV 4. Home office: Beoplay M5. Kitchen: Beoplay M5. Travel: Beoplay H8, Beoplay A1. NAS: WD My Cloud Home / Plex DLNA Server.
Dyssegaard:My DLNA play queue on my BS Core also loops/restarts after the last track, but I see this as a feature more than an issue
I think it's only 3D Touch for the app icon on the iPhone home screen.
If you long press on it you get 3 options
- Send Feedback (Beta version)
- All Standby
- Setup product.
3D Touch can be useful - but I would suggest that the above options aren't the most useful. All Standby is, but I can think of more useful options.
Other apps I use bring up 4 or 5 options with 3D Touch - so there is "space" for more.
Can't see any 3D Touch in app - so any possibilities that could be explored in app, but nothing yet.
Hi all
Yes, 2.4 is out in beta. This not a major release for us but preparations for features and updates we're doing this spring/summer.
3d touch is now very basic. We will add more features in upcoming releases, for example quick access to selected products. This could be very valuable for accessing the remote for a TV
@Dyssegaard: When the play queue loops the loop icon is disabled?
Br
Thomas
MrAndersen: @Dyssegaard: When the play queue loops the loop icon is disabled?
I see no loop icon there/DLNA playback, either.
@Thomas - could you post a picure of how it should look?
MrAndersen: @Dyssegaard: When the play queue loops the loop icon is disabled? Br Thomas
Millemissen:I see no loop icon there/DLNA playback, either. @Thomas - could you post a picure of how it should look? MM There is a tv - and there is a BV.
Oh, I found that!
Since I am an album listener, I never cared for ‘the play queue’....and never looked there.
Now I see, that you can activate/deactivate that........which - of course - is important for playlist listeners.
Millemissen:........which - of course - is important for playlist listeners.MMThere is a tv - and there is a BV.
In that sense an album is also a play queue, a playlist - so I would have been wondering too, if it would have been set to on.
Millemissen:so I would have been wondering too, if it would have been set to on.
I’ll have to check that out first.....since I hardly ever play anything from my NAS anymore.
Actually there seems to be an issue there.
No matter if toggled on or off the queue/list was repeated from the beginning, after the last track had finished.
Millemissen: Actually there seems to be an issue there. No matter if toggled on or off the queue/list was repeated from the beginning, after the last track had finished. MM There is a tv - and there is a BV.
Will look into this, thanks. I hope the issue is app side and not product side, then it should be fixable.
MrAndersen:Will look into this, thanks. I hope the issue is app side and not product side, then it should be fixable.
After some investigation I'm suspecting it relates to the products as well. It wasn't doable before our 2.4 deadline, but I will move it into 2.5
MrAndersen: After some investigation I'm suspecting it relates to the products as well. It wasn't doable before our 2.4 deadline, but I will move it into 2.5
Perfect, thanks
Another "interesting" B&O multiroom behavior:
Core is my main product
BS 1 + A6 + M5 + M3 have joined the Core in a B&O multiroom group
I start playing a DLNA album which adds the album's tracks in the now playing list
If I empty the now playing list (Trash Icon), Core stops playing as BS 1 and M3 do .... but A6 and M5 continue playing ..... something wrong here isn't it ?
We have now verified that this is a product issue. I have transferred the bug to them and will get back with an ETA on a fix.
When we test it, it always repeats. We cannot turn it off.
MrAndersen: Hi all We have now verified that this is a product issue. I have transferred the bug to them and will get back with an ETA on a fix. When we test it, it always repeats. We cannot turn it off.
Thanks for the update, can't wait for product update then, ALL products .... as they all behave the same.
MrAndersen:Hi allWe have now verified that this is a product issue. I have transferred the bug to them and will get back with an ETA on a fix. When we test it, it always repeats. We cannot turn it off.
Dyssegaard:My Beoplay M5 was updated to version 1.20.30101.247491601 tonight, and now the loop icon works
I updated mine and it seems that the looping function is consistent on the M5, I'll do more tests too
Note: when the icon is bold it means that the function is engaged.
Unfortunately this M5 update does not solve the unsolicited looping issue, which is consistent with Mr Andersen message where he just reported it to the product developers.
mbolo01:Unfortunately this M5 update does not solve the unsolicited looping issue, which is consistent with Mr Andersen message where he just reported it to the product developers. BS Moment, BS Core, BS Ouverture, BS1, BL18, BL19, BL8000 + RCV1, A6, M5, M3, A1, H5, TR1
