Avant 55 and Beoplay M3,M5
JSebastian
Posts 2
JSebastian Posted: Wed, Jan 23 2019 4:37 PM
Hello
I would like to have the in-expensive M3 or M5 as speakers in different rooms and use my Avant 55 as streaming source.
Is this supported out of the box or am I perhaps looking at the wrong products?
Can I use the Android app as remote control?
Hiort
Sweden
Posts 2,895
Hiort replied on Sat, Jan 26 2019 4:45 PM
That will work just fine.
I’m not familiar with the android app but I would say yes to that question as well.
Millemissen
Flensborg, Denmark
Posts 14,680
Hiort is right!
’Out of the box’, though, I am not sure.
You will have to set up these devices to cooperate and you’ (probably) have to configure the local list of the M3/5’s.
Similar to how it is done with my Essence.
You can activate what you need and move the source up/down in the list.
.....if that is what you mean by ‘use my Avant 55 as streaming source
JSebastian
Posts 2
Thanks a lot!
Page 1 of 1 (4 items) | RSS
