Dom
2x BeoSystem 3, BeoSystem 5000, BeoSystem 6500, 2x BeoMaster 7000, 2 pair of BeoLab Penta mk2, AV 7000, Beolab 4000, BeoSound 4000, Playmaker, BeoLab 2500, S-45, S-45.2, RL-140, CX-50, C-75, 3x CX-100, 3x MCL2 link rooms, 3x Beolab 2000, M3, P2, Earset, A8 earphones, A3, 2x 4001 relay, H3, H3 ANC, H6, 2014 Audi S5 with B&O sound, and ambio
Hello
think you can search in DIY furniture shops or IKEA.
Have a nice day
MArco
For me it was hard to find because the plastic foot is overmolded onto the bolt.
I ended up designing a plastic foot and made them on a 3D printer and used a normal socket cap bolt through the middle.
https://archivedforum2.beoworld.org/forums/p/16302/141187.aspx#141187
Beo4 'til I die!
DMacri:I’m talking about the 5 plastic feet to keep from marking up hardwood floors:
Clear - that's what I was referring to and what I ended up cloning.
When I bought my Pentas, some of the plastic feet were busted off and as a result the column wasn't very stable on a carpeted floor. I looked for suitable replacements but couldn't find any so I just modeled a 'foot' and printed 10 of them, picked up some bolts on the way home. 1 day project.
I uploaded the model to Shapeways so people could buy them (don't worry, I'm not the one price gouging here, thank Shapeways).
Find HERE
If you would like the model of the foot for yourself to try and print on your own, just let me know and I'll try to dig it up and pass it on.
Unfortunately I don't remember the bolt I used specifically. Project was from a while ago.
DMacri:Ok so clearly I’m missing something. I don’t see how a cubic piece in plastic is meant to replace a little circular rubber button. It’s just supposed to be a little push on part that goes on the end of the actual foot. I guess I’m just looking for the little caps, not the whole foot.
No it was me who was missing something - I didn't realize there was an optional soft rubber version My mistake. That I don't have experience with.
I must have several original unused plastic feet laying here somewhere. They came with the set I bought in 1999. A spare set of feet.
I could measure them and print them with a more flexible filament, like a TPU version.
Hi DMacri
The plastic part on Penta's feet can over time get riser. Metal plate under plastic / mirrorThe surface can also rust. If that happens, ugly blemishes will eventually occur.
What can we do then: Personally I found a set of used Penta, with feet where plastic /the mirror was nice. I've also seen it possible to find a set on eBay.
You can also start painting them. First with gray paint, then fine sanded andcleaned. Then paint twice with eg satin black, so that they will again mirror.
