Hello B&O Friends, I´m searching to find a Remote Main Switch 4002 (for the EU market), I would like to have one to control my separate SUB woofer that is connected to my BV-40.Or does anyone have another option to control the power via a power link socket or any other way via the BV 7-40?RegardsStefan
BS3 DVB-HD, BV7-40 MKIII, BC6-26, BC6-23, BV4-50/BS2, BS5, BS9000, BL3500, MLGW, BLGW, PlayMaker, - BS6500, BS4500, LX6000, VX7000, MX5500, VX5000 - Beo6, Beo5, BeoTimex2, Linctonic
Hello Stefan,
Which model of subwoofer are you using with the BV7-40 TV please? We can then help you to find a way to control this.
Kind regards, Steve.
Steve.
www.soundsheavenly.com
Hi Stefan,
No problem, if you can please let me know the sub model number when you are next there, I can help you to get it connected.
