Hi
I decided to replace the foam in my BL8000s. They have been working fine but as the foam causes such damage with time I thought I'd better do it. I didn't buy a kit but bought foam...cut it to size etc. Old foam was crumbly and almost felt wet.
Once I put the speakers together again I was absolutely astonished at the change in the sound! They sounded magnificent. Treble was clearer...bass much tighter sounding and overall amazing. To be honest I almost had a tear in my eye.
Anyone who hasn't changed their foam on their speakers....do it...its worth the hassle!
Hi BenSA!
Mine are 20 years old,still going strong.Never opened.All I have done,some 4 years ago replaced fret cloths(all by myself)
Now,looks like it's time to check foam.Can you tell me what kind of foam you used as replacement?
Beogram 6500 MMC2,Beosound Ouverture,2xBeolab 8000,2xBelolab 4000,Beolab 2,Beolab 7.2,Beo4 navi, 2xBeocom2,Serene,Beosystem 3 mk3,H6 2nd gen,Earphones E8,A8,A9 keyring,Beoplay A1,Bottle opener,Beoplay A2 active(thanks Botty)Wine Set(thanks Botty),4Ktv Samsung 55'',Beolab 7.1 with 42''Panasonic plasma,,Oppo udp-203, LinTronic.
Hi OldJack
To be honest I just went to a foam supplier and just looked for one that looked the most similar. I didn't worry about the colour as its inside the speaker.
Beolab 50, Beolab 8000 x 2, Beolab 4000 x 2, BeoSound Core, BeoSound 9000, BeoSound Century, BeoLit 15, BeoPlay A1, BeoPlay P2, BeoPlay H9 3rd Gen, BeoPlay H6, EarSet 3i, BeoVision Eclipse Gen 2 55", BeoPlay V1-40, BeoCom 6000 and so much else :)
I guess we are not talking about rubber surrounds around speakers,but about this
http://archivedforum2.beoworld.org/forums/t/15962.aspx
I meant the interior foam..the dampening. I would haven't though that changing it would have made such a drastic change in the sound but it did. The old foam totally changes consistency of time becomes like glue. Clearly the change effects the sound.
I am hoping that I'm not to late to get an answer to this question...
I was able to buy the 'official' foam parts for my BL8000's.
What did you use to 'glue' the replacement foam into place?
Thank you in advance.
Thames: I am hoping that I'm not to late to get an answer to this question... I was able to buy the 'official' foam parts for my BL8000's. What did you use to 'glue' the replacement foam into place? Thank you in advance.
None, the official foam has a sheet with instructions. No glue needed.
Ok, I see now. I guess I should have considered that it is just a friction fit. Still seems like some of the long pieces might shift around.
Thank you for that!
BTW: I think the B&O dealer may have sold me too many of these foam kits. I have 2 speakers and 6 sets of foam. Anyone need the extras?
Hi Thames,
I have recently bought a gorgeous pair of mk 1 beolab 8000's. It sounds like I should replace the foam. If you still have spare then please let me know if you would like to sell a set. And I would appreciate any tips on the process. Thanks!
I'm super sorry I didn't see your post until now. Do you still need the foam?
I still have qty 4 of the 'kits', enough for 2 pairs of speakers.
If you (or anyone else) still needs them let me know. I'm not sure of the 'correct' way to trade contact information on the forum so let me know.
Hi Alls,
Thanks to Thames, a template to custom make BL8000 foams is now available in the wiki section of the forum.
Hi Thames, Im after some Beolab 8000 interior foam for mine. Do you still have these to sell? PM if you want.
Beolab 8000 x 2
Beolab 1
Beolab 2
Beovision 7-40
Beosound 9000
Beosound Ouverture
Beolit 12
I have some new foam on the way, laser cut to the correct sizes (some jobs I'll pay up for !). Before it arrives, I was wondering if there was any merit in further dampening the case by adding Dynamat to the inside before the foam ? It would certainly add mass to the cases.
