hi knowledgable people.
Purchased a Beosound 1 ex display earlier today from my local B&O store. But its been a nightmare. Software version is:
Ok, i checked my BS1 and it's version is 1.19. It did say last week on the Beotool that Beoportal was unreachable and i had problems updating it.
I reset the device using the button (cog button) on the underside and re "paired" it from scratch ie find it on your iphone, add it back to your network etc
Then it updated.
It's the first time i have had to do that
PS i removed it from the BeoApp too
First test though: is it working?
Yes, working.
Have just reset it.
Still will not update software! :(
How do you update it without using the B&O App? Is there a way to manually update it. And it keeps showing as a generic speaker in the app??
So grateful for any help given
David
Morning all.
Anyone out there that can help me? No one knows B&O products like you guys.
Been viewed 82 times and yet only one kind person has offered any help?
David:Morning all. Anyone out there that can help me? No one knows B&O products like you guys. Been viewed 82 times and yet only one kind person has offered any help? Thanks David
David: hi knowledgable people. Purchased a Beosound 1 ex display earlier today from my local B&O store. But its been a nightmare. Software version is: Version 1.17.22535.7625124 And it won’t update to latest. Beotool says Beoportal unreachable. Won’t connect, Deezer not working, chrome cast wont work etc etc etc How do I manually update? Some one please help, I am at my wits end David
David,
1. Use the Bang & Olufsen app to find the IP address of the product. The IP can be seen after selecting the BeoSound 1 settings in the app.
2. Connect to the IP via a browser on a PC or via mobile browser by typing the number in the adress-bar. Now the BeoSound 1 webpages should be seen in the browser.
3. Select the menu "UPDATE PRODUCT SOFTWARE"
Hope this helps,
Ulrike
Thank you so much Guys
right I’m in to that page you said, but it says update from a local file? I don’t have the new firmware?
...and stills says running latest firmware, but its not!
If any one has the latest firmware they can share with me? Be so appreciated. Gutted all this hassle with something I paid a lot for.
Thanks in advance
Sorry, my fault (I do have a file, have downgraded my BS2 several times after new firmware issues)
So:
Go to "New Firmware Available"
Send you a screenshot:
Sorry, confused. How do I get the file from you?
Mine isn’t showing that option. Just says product software up to date which it isnt as we know.
How can I download the file from you? Dropbox? Email it me?
Much appreciated and thank you for your help here.
did you try it with a PC? It should show up then ..!
Sorry, I cannot give you the right file, mine is for a Beodound 2.
I don't own a BS1.
Hi
yes, on Macbook now. Still nothing.
And isn't the firmware for all devices? Would be fine.
No, firmware is different.
First enable automatic software update!
(I haven't done done this, because I want to keep the downloaded file)
I send you some screenshots how to do it from a windows PC:
yes, done all that. still Nothing. Just says software up to date. So frustrating
Gutted.
Can you post a screenshot from your Mac/PC?
You may need this as well for sending it to Beocare ..
David: Purchased a Beosound 1 ex display earlier today from my local B&O store. But its been a nightmare.
What did your ‘local B&O store’ do to help you?
Hi there
They are closed today sadly and I have work tomorrow. Ill email them in the morning and see what they say.
Just wish I had never bought it :(
ask Beocare for assistance:
https://bogo.custhelp.com/app/ask
Thank you!
yes, like that, but strangely mine doesn't show up the serial number or item number?
Yes, the beotool app shows red dots on beoprtal cant be reached and software not been looked for.
And again doesn't show the serial number or item number?
Yes, accessed that screen from my macbook, no different. Still won't update or even show new software
HI
Maybe, would make sense. But surely a reset would clear that?
A couple of weeks ago my app showed no connection to BeoPortal on multiple devices. I was also trying to an install an update that was being pushed to me by B and O and it did not show up. I uninstalled all products from the app, and then reinstalled them in the app and the connection was restored, the update appeared, and was installed.
Update
Beosound returned to store earlier and full refund given.
Sad and frustrating experience all round.
Thank you you all for your help, it’s been greatly appreciated.
