I have a Beogram 3000 that was treated very gently during its years of use, then put in storage in my living space (as opposed to attic or garage!) for many years. I recently plugged it in but get nothing. No power light or movement. I've been scouring the Internet looking for a repair option, but having no luck. Any ideas out there?
There are multiple kinds of BG3000, one tangential deck from the 80's and two radials with a wood plint from the 60's and 70's. Which one do you have?
No power light or movement suggests no power is getting in at all. I'd start with checking the internal fuse, easy job.
