BS3200 display brightness
f5434964
Austria
Posts 206
f5434964 Posted: Fri, Feb 15 2019 4:29 PM
Hello!
Is there an option to change the brightness of the display of an Beosound 3200? Mine seems to be a little bit dark...
Best regards
Elmar
solderon29
U.K.West Midlands
Posts 764
There is an adjustment(contrast),but it's deep inside the machine and it involve's having to dismantle the front to get to it!
Also,there is an automatic display backlight control,which senses the brightness in the room and varies the backlight level accordingly.
Make sure that the back of the glass doors are clean,as they can become coated with a film of dirt from say,an open fire or wood burner stove.This could confuse the operation of the backlight control.
Nick
f5434964
Austria
Posts 206
f5434964 replied on Sun, Feb 17 2019 8:54 AM
Thank you Nick for your detailed answer!
I do not want to open the BS - I just thought that there might be an option/setting hidden in a menu.
Maybe somethings wrong with the sensor - I can not recognize any difference of brightness due change of room light...
Best regards Elmar
Page 1 of 1 (3 items) | RSS
