Hello,
I've bought a MMC 6000 in good looking condition, after testing it seems to have one problem. As the arm lows I can hear well for 1 second, after that the right channel almost disappear, if balance to right and power up the amplifier (a lot) I can hear but in normal condition just got the left channel sound.
Any one can help me?
Regards
“if balance to right and power up the amplifier (a lot) I can hear but in normal condition just got the left channel sound.”
Are you actually getting both channels? i.e. using a test record?
Best regards Alistair
Audio Origin
yes, i get both channel at same volume for about 1 second, then right channel disappear almost disappear for complete.
Hi ProGram, I will check that tonight.
