Missing menu(choice) BeoVision 7-40 mk III Beo4 joystick
carreracs
Posts 44
carreracs Posted: Sun, Feb 17 2019 10:06 PM
Hi
Just bought a Beo4 joystick for easier navigation on my BV7-40 mk III. The mk III has BeoSystem 3 and is the same as I have on my BeoVision 9, however I do not find the menu choice on my BV-7 regarding the Beo4 where I can chose with or without joystick navigation.
Any ideas?
Christian
Schletti82
Posts 128
Schletti82 replied on Mon, Feb 18 2019 12:52 AM
Beovision 7-40 Mk3 doesn‘t have this Option.
this Option is available at mk4 to mk 6 with blueray player installed
carreracs
Posts 44
carreracs replied on Mon, Feb 18 2019 12:11 PM
Ouch, bad research 😬
Thought this was from Mk III, thanks for your reply.
Christian
stefan
200 miles from Struer
Posts 2,920
stefan replied on Mon, Feb 18 2019 12:18 PM
Correct. My MKIII is working great with my Beo4 navi.
Maybe your BV7 needs an update (?) My BV7 has the "later" what I call it - blck face ui -
When you update your BV, don`t forget to update your pucs, too.
Stefan
9 LEE
Eastbourne, UK
Posts 7,218
9 LEE replied on Mon, Feb 18 2019 12:29 PM
I thought the same... The later SW and menu gave you the Navi option.
carreracs
Posts 44
carreracs replied on Mon, Feb 18 2019 2:01 PM
Ok, thanks :)
Might be able to fix it then!
Christian
carreracs
Posts 44
Ok, thanks :)
Christian
Millemissen
Flensborg, Denmark
Posts 14,680
Yes, your MK3 definitely needs a later sw.
However, only a B&O technician can do that - the costs depends on where you are located....and probably on your relations to the dealer etc.
If you should decide for this, be sure to have your PUC list updated too with the recent/needed codes.
Page 1 of 1 (8 items) | RSS
