If ever you felt like committing suicide?
This post has 12 Replies | 0 Followers
Beofile7
Posts 150
Beofile7 Posted: Fri, Feb 22 2019 3:32 PM
If ever you felt like committing suicide just buy Beolab50’s!
Never in my whole existence have I experienced anything comparable to this!
trying to connect to my WLAN, it will not. It says it will, but it does not. B&O tell me it will but it does not. The dealer tells me it will but it does not. The internet tells me it will but it does not. My Godmother tells me it will, but it does not.
So,two weeks later, many internet friendly guys, much better than me have tried and given up, the dealer promised to do it. But no response! No dealer, no assistance.
so now I have a pair ofBeolab 50’s that are about to be thrown in the lake opposite! I have lost 5 years off my life because of these MF’s and have had no real assistance fromB&O other than to repeat stating what ?I am already doing.
StuffB&O. This is absolutely the last ever purchase! You deserve to go to the wall. And ?I know you will.
9 LEE
Eastbourne, UK
Posts 7,218
9 LEE replied on Fri, Feb 22 2019 3:43 PM
Hopefully you feel better after that... Wink
Has your dealer gone bust?  If so, have you contacted B&O directly?  I think Razlaw posted some new contact details for B&O where they are more than happy to help with any issues...  Clearly yours are more deep-rooted by the looks of things and will need a visit, probably followed by a new pair of speakers if nobody can get them to work.
Lee
Beofile7
Posts 150
Beofile7 replied on Fri, Feb 22 2019 3:56 PM
Hej Lee
Dealer has not gone bust, he has promised to sort this 3 days ago. But since then no contact! B&O have been contacted directly yes. But everytime it’s a different person just talking down to me. Standard connection....Do this, do that. What the hell do you think I have been doing for weeks? Nothing effing works!!! Nothing.
“The problem is my internet.” Is it? My Beovision connects with no issues along with other products so don’t tell me this sh1t!
Mr B&O...Get your effing *** out here and sort this. I have been buying these products for 33 years. It is all coming to an end right here, right now!
9 LEE
Eastbourne, UK
Posts 7,218
9 LEE replied on Fri, Feb 22 2019 4:05 PM
Hmm... this is not good. Especially since you made a purchase with the value similar to that of a family car!
If you really are getting nowhere, hopefully you paid for them on a credit card?  That way you can just raise a case with them and they'll hold the money from the dealer. This always makes them sit up and listen...
So sorry to hear it has come to this. This is not how B&O should be, and hopefully someone who can turn some wheels is reading this.
Lee
Beofile7
Posts 150
Beofile7 replied on Fri, Feb 22 2019 4:34 PM
You are right... buy the car, drive it off Beachy Head. You are guaranteed at least 10 seconds of pleasure. 10 seconds more than Ihave had with Beolab 50!
chucky
Posts 331
chucky replied on Fri, Feb 22 2019 4:46 PM
Oef, this is really bad. I feel for you. Tell the dealer to pick them up at least you do not have to look at them and let them sort it in their office and connect them there. Imho the first thing they should do is send a mechanic are they completely nutsss?
Chris Townsend
Qatar
Posts 3,531
Where's the lake?Yes - thumbs up
Carolpa
Posts 1,700
Silver Member
Carolpa replied on Fri, Feb 22 2019 7:22 PM
Beofile7:
Sorry, but I won't buy this story.
If you spend this amount of money and encounter this amount of problems and the dealer didn't solve the problem right away, then by now I would have had a bad experience but I would have my money back.
Simple as that
Beofile7
Posts 150
Beofile7 replied on Fri, Feb 22 2019 8:18 PM
I live in a country where no-one does anything, ever without payment! So I am expected to pay extra to have this sorted!!! I have reluctantly agreed out of desperation. Days later......still waiting!
9 LEE
Eastbourne, UK
Posts 7,218
9 LEE replied on Fri, Feb 22 2019 8:40 PM
Hang on....  you're having to pay money to get someone to sort out your speakers which are actually under warranty?!!!
andy_js
Englandshire
Posts 223
andy_js replied on Fri, Feb 22 2019 11:21 PM
“Your Internet is the problem” was the standard line given to all the folks (myself included) who bought the Moment only for it not to work because the software was flawed. I can only imagine that history is repeating itself again. If using a wired connection is an option I suggest trying that and then doing a firmware update to see if that helps resolve the problem.
Esax
Posts 323
Esax replied on Fri, Feb 22 2019 11:24 PM
Have you tried to connect by cabel direct to your router?
Beovision 7-55 MK1 red, Beolab 10 red. Beolab 50, all black. Beolab 17 broken ice. Beolab transmitter. Apple tv4 and apple express 2.
Mikipidia
Posts 2,169
Mikipidia replied on Fri, Feb 22 2019 11:43 PM
heard the same lines when my lab 50's were faulty, I know how you feel. There is a known wifi chip issue if i recall correctly from the manuals I've seen but wasn't supposed to. It can also be that you're to quick on the draw to try again. 8/10 times with setup my wifi setup failed and the app crashed etc. then next time after a few minutes after having power cycled it again it would mysteriously work. Also the app rarely connects on the first try, a quick double tap usually does the trick for what its worth...
Mikipedi4 on Twitch: https://www.twitch.tv/mikipedi4
Mikipedia on Intagram: https://www.instagram.com/mikipedi4/
Old: Beosound 9000 mk3, Beolab 3's, Beovision Eclipse, Beolab 1's, Beolab 2, Beovision 10-46, Overture 2300, beolab 8000's, Beolab 4000's, Beovision avant 32" etc. etc.
Page 1 of 1 (13 items) | RSS
