Can't access AV IN on Beovision 11 with BeoRemote One
This post has 20 Replies | 2 Followers
lundmark
Stockholm, Sweden
Posts 105
lundmark Posted: Sun, Feb 24 2019 12:26 PM
There doesn't seem to be a command in the BeoRemote One to access the AV input on the Beovision 11 mk2. I've tried adding all the sources on the remote but none of them will activate the input.
There is one labeled AV IN on the remote but it activates the radio instead. Is this a bug? I will have to use the menus to access this source instead of the TV or MUSIC source buttons on the remote. Very frustrating.
madskp
Denmark
Posts 321
madskp replied on Sun, Feb 24 2019 1:03 PM
On the Beoplay V1 you have to assign the AV in port to a source in the setup menu of the TV the same way you asign HDMI ports. Guess its the same on the BV11.
lundmark
Stockholm, Sweden
Posts 105
lundmark replied on Sun, Feb 24 2019 1:29 PM
This used to work when using the Beo4 remote, but there is no such option when the TV is configured to use a BeoRemote One.
Millemissen
Flensborg, Denmark
Posts 14,680
If you have started the AV IN source from the Source Menu, can you then assign a MyButton to it?
If yes, that might be a workaround.
madskp
Denmark
Posts 321
madskp replied on Sun, Feb 24 2019 3:38 PM
I havent tried a beoremote one, but shouldent the source be the same as on a BEO4; V.MEM for example if thats the dource assigned to the AV In port?
What source button did you use on the BEO4?
Dyssegaard
Copenhagen, Denmark
Posts 263
lundmark:
On my BeoRemote One BT I’m able to add AV IN under TV sources for my BV 11 - see screen shot below:
I do this on the remote by selecting:
LIST / Settings / TV-sources / Show / AV IN
Edit - sorry I didn’t see in your first post that you found it yourselfWink
Best regards - Dyssegaard
Living room: Beovision Eclipse 55, Beolab 3 / R1 (back), Beolab 2 / R1 (sub), AppleTV 4K. Bedroom: Beovision 11-40, AppleTV 4. Home office: Beoplay M5. Kitchen: Beoplay M5. Travel: Beoplay H8, Beoplay A1. NAS: WD My Cloud Home / Plex DLNA Server.
lundmark
Stockholm, Sweden
Posts 105
lundmark replied on Sun, Feb 24 2019 3:52 PM
Millemissen:
Yes, that's what I need to do I think.
madskp:
I could use any button, because the source menu allowed for setting any of the buttons. This is not the case if the TV is set to use the BeoRemote One. Then you cannot assign buttons—the remote is supposed to have all the commands listed.
lundmark
Stockholm, Sweden
Posts 105
lundmark replied on Sun, Feb 24 2019 3:53 PM
Dyssegaard:
Yes! It's there but it starts RADIO on my TV for some stupid reason! I
Dyssegaard
Copenhagen, Denmark
Posts 263
lundmark:
I have just tried to use it, and on my BV11 it start up the AV source as expected.
lundmark
Stockholm, Sweden
Posts 105
lundmark replied on Sun, Feb 24 2019 4:07 PM
Makes sense. I’ve reset my remote and the issue persists. Somethings going on with the TV
Millemissen
Flensborg, Denmark
Posts 14,680
Could you perhaps post a picture (probably two) of the Source Menu of the tv?
lundmark
Stockholm, Sweden
Posts 105
lundmark replied on Mon, Feb 25 2019 8:31 AM
lundmark
Stockholm, Sweden
Posts 105
lundmark replied on Mon, Feb 25 2019 8:33 AM
It would appear the (SOURCE) in the parenthesis is the 'button' that will activate it.If so then it makes sense that AV IN does not activate. However I don't know how to configure these.
Millemissen
Flensborg, Denmark
Posts 14,680
What are your options under Från Standby?
It is now set to Inga (which I suppose means Nothing).
lundmark
Stockholm, Sweden
Posts 105
lundmark replied on Mon, Feb 25 2019 9:08 AM
Yeah, it's set to none. The only options are None and TV. When set to TV, the TV button on the remote starts the Beovision on the AV input, so that works as expected. But it's not really how I'd like it.
Millemissen
Flensborg, Denmark
Posts 14,680
lundmark:
What would you expect to happen, then?
Isn’t the TV command/button ok?
lundmark
Stockholm, Sweden
Posts 105
lundmark replied on Mon, Feb 25 2019 6:45 PM
That option is to turn on the source from standby, not switch to it when the TV is already on. I would prefer to be able to access it from the source list in the remote
lundmark
Stockholm, Sweden
Posts 105
lundmark
Stockholm, Sweden
Posts 105
madskp
Denmark
Posts 321
madskp replied on Mon, Feb 25 2019 6:47 PM
On my V1 I am only able to assign sources that is not all ready in use. Seems to me that your only availible source is TV. Dont know if this is somehow related to the Beoremote One though
lundmark
Stockholm, Sweden
Posts 105
lundmark replied on Mon, Feb 25 2019 7:14 PM
Correct but I’m not interested in the standby start feature. I just want to be able to switch source from the remote’s menu, but none of the menu items take me to the correct input
Page 1 of 1 (21 items) | RSS
