Beolab 17, low volume
This post has 15 Replies | 0 Followers
KjetilA
Posts 14
KjetilA Posted: Tue, Feb 26 2019 7:51 PM
I have a set of beolab 17 connected to a transmitter1. As for the source I have a beosound core connected to the transmitter with a toslink. But the volume is quite low I think. If I set the volume at 25% there is almost no sound coming from the speakers, at 50% it is possible to hear something, but I have to go up to at least 75% to get some kind og "living room volume".
Does anyone have any tips regarding the volume? I have tried to reset both speakers and the transmitter1 several times, but nothing seems to help.
mbolo01
Louannec - France
Posts 2,035
mbolo01 replied on Tue, Feb 26 2019 7:54 PM
Why don't you connect the Core to the PL port of the TR1? It is made for that
KjetilA
Posts 14
KjetilA replied on Tue, Feb 26 2019 8:31 PM
Good question! I just haven't thought of it i think. Will it matter (help), and in that case, what will be the difference you think?
Millemissen
Flensborg, Denmark
Posts 14,680
KjetilA:
The short answer is, it will work!
However, before you change the cable setup, do have a look in the settings of the Core = optical out can be volume regulated.
This is can be set with the app under configuration-sound settings-optical out.
Have a look at the screenshots from liberal in this thread and check, if you can change anything there - in order to keep the connection via spdif out:
https://archivedforum2.beoworld.org/forums/p/28411/223684.aspx
mbolo01
Louannec - France
Posts 2,035
mbolo01 replied on Tue, Feb 26 2019 10:19 PM
KjetilA:
You’ll get the volume control, and possibly a better product integration within the TR1 and the B&O ecosystem, as well as more option in the future if you acquire other PL capable products.
I would save the optical input of the TR1 for other non B&O products that have optical output and volume control.
KjetilA
Posts 14
KjetilA replied on Wed, Feb 27 2019 8:07 AM
Thanks. I have already changed the settings on the optical output  to make the volume adjustable. The problem has been that the highest volume has been too low.
I have switched to PL as suggested and it actually helped a lot! Big Smile Thanks again!
Now I only have to fix a hiss in my speakers that i belive comes from my T1, and the fact that the T1 have problems connecting to my speakers from time to time and 'breaks up' the sound so that I have to reset and connect it to my speakers again.
kallasr
Germany
Posts 2,562
kallasr replied on Wed, Feb 27 2019 9:03 AM
Make sure to update the TR1 via USB Stick to the latest Software available.
This helped a lot in my case.
Ralf
KjetilA
Posts 14
KjetilA replied on Wed, Feb 27 2019 9:05 AM
I updated it yesterday, but the hiss didn't go away. It seemed like the T1 froze after the update though, with the red light in front left on until I disconnected the t1 from the power.
mbolo01
Louannec - France
Posts 2,035
mbolo01 replied on Wed, Feb 27 2019 9:05 AM
KjetilA:
Do you have a 5 GHz Wifi network nearby? This could seriously impact the quality of the TR1 <-> speakers communication.
I would aslo check the version of the TR1 Software as well as the speakers' one. The latest is 1.1.4.5310 dated January 15 2018 including:
wpl_tx:   1.1.4.5310 (FEP: 1.15a), (DSP: 0.60a), (SUMMIT: 0204-01)
BeoLab17: 1.1.5.6210 (FEP: 1.90a), (DSP: 1.96j), (SUMMIT: 0204-01)
BeoLab18: 1.1.5.6210 (FEP: 1.90a), (DSP: 1.96j), (SUMMIT: 0204-01)
BeoLab19: 1.1.5.6210 (FEP: 1.90a), (DSP: 1.96j), (SUMMIT: 0204-01)
BeoLab20: 1.1.5.6210 (FEP: 1.90a), (DSP: 1.96j), (SUMMIT: 0204-01)
BeoLabR1: 1.0.1.6211 (FEP: 1.00a),               (SUMMIT: 0204-01)
Lastly, the placement of the TR1 is also a factor to consider when very close or aligned with the speakers, sometimes moving it a very few cm solves communication issues.
KjetilA
Posts 14
KjetilA replied on Fri, Mar 1 2019 8:52 PM
I have updated the software, but how do I check that the new software have been installed? How do I check the version?
mbolo01
Louannec - France
Posts 2,035
mbolo01 replied on Sat, Mar 2 2019 7:54 AM
KjetilA:
You should have a LOG file in the USB key that you inserted in the TR1 to perform the update. This log should have all the information you need.
KjetilA
Posts 14
KjetilA replied on Sun, Mar 3 2019 10:31 AM
I have three files on my memory stick after update.
A Debug, a WPL_DUMP and a RRaA file.
I'm guessing that the update failed since there is a debug-file after the update?
mbolo01
Louannec - France
Posts 2,035
mbolo01 replied on Sun, Mar 3 2019 10:45 AM
Can you post the content of your DEBUG.LOG please?
KjetilA
Posts 14
KjetilA replied on Sun, Mar 3 2019 12:18 PM
[00003788]Summit uart: DeviceID = 0x16,  BranchID = 0x02
[00004128]MEMSTICK SW update check starting 00002070 Total 00002070
[00004140]Summit uart: System Data CHECKSUM Error...Calling I2CSlaveWriteRelease()
[00004177]NumberOfSpeaker : 2
[00004190]WPL         : Event  0 received in state 0, new State 2
[00004270]DSP booting from FEP!
[00004560]WPL         : Event  2 received in state 2, new State 2
[00004568]Service counter ERROR
[00004679]WPL         : Event  4 received in state 2, new State 3
[00004692]Summit uart: CHECKSUM Error...Calling I2CSlaveWriteRelease()
[00010198]Summit uart: Energy pre-scan complete, enabling RD
[00010211]Summit beacon_cmd (time:5500) Status: 0x01
[00010223]Summit uart: Energy Detected W
[00010232]Summit uart: cnt = 127
[00010245]Summit uart: W = 12 RD Off
[00010253]Summit uart: M = 15
[00010266]Summit uart: Quality Hop Enabled
[00010313]Summit uart: SpeakerCount for Zone 0: 2
[00010349]Summit uart: Restoring Slave 0... succeeded
[00010385]Summit uart: Restoring Slave 1... succeeded
[00010403]Summit uart: npeakerCount for Zone 1: 0
[00010417]restore speaker configuration Status: 0x01
[00010425]Summit uart: SpeakerCe 6: 0
[00010433]Summit uart: SpeakerCe 6: 0
[00010444]Summit uart: SpeakerCount for Zon48KHz
[00010486]run_cmd Status: 0x01
[00010618]master Mac Address            02 EA 36 01 9B 8C
[00010805]Summit uart: Hop[0][0] - network quality: 95
[00010820]Summit uart: W = 8 RD Off
[00010829]Summit uart: M = 15
[00010846]Speaker ID 0 Configuration: Mac Address                   02 EA 3D 00 1C 1B
[00010857]FW Version                    204-1
[00010870]Speaker Mode=2 Slot=2  SpeakerDescription=0 BeoLab17
[00011035]Speaker ID 1 Configuration: Mac Address                   02 EA 3D 00 1C 16
[00011043]FW Version                    204-1
[00011058]Speaker Mode=3 Slot=1  SpeakerDescription=0 BeoLab17
[00011073]WPL_TX SW updating Speaker 1 Not done
[00011081]WPL_TX SW updating Speaker 0 Not done
[00011094]MEMSTICK SW update check completed 00006967 Total 00009037
[00011201]MCONF         : Event 21 received in state 0, new State 0
[00011349]Sense status, PL=0 TOSLINK=1 LINE=0 USBB=0 USBA=0 ATI=0 ALWAYSON=1 TESTMODE=OFF PL/Line Switch=POWERLINK, ASSOCIATED
[00014163]Summit uart: Hop[0][0] - network quality: 95
[00014172]Summit uart: W = 14 RD Off
[00014182]Summit uart: M = 15
[00014240]Network quality is Very Bad   95
[00014560]Summit uart: Radar Detected M
[00014569]Summit uart: cnt = 24
[00014582]Summit uart: DFS_Channel(CAC) = 16
[00014590]Summit uart: W = 14 RD Off
[00014605]Summit uart: M = 16
[00015739]Summit uart: Energy pre-scan complete, enabling RD
[00015772]Summit uart: Energy Detected W
[00015779]Summit uart: cnt = 52
[00015791]Summit uart: W = 8 RD Off
[00015800]Summit uart: M = 16
[00016833]Summit uart: Radar Detected M
[00016840]Summit uart: cnt = 1
[00016853]Summit uart: DFS_Channel(CAC) = 29
[00016862]Summit uart: W = 8 RD Off
[00016877]Summit uart: M = 29
[00018741]Summit uart: Energy pre-scan complete, enabling RD
[00036779]Summit uart: Energy Detected W
[00036788]Summit uart: cnt = 58
[00036801]Summit uart: W = 10 RD Off
[00036809]Summit uart: M = 29
[00039757]Summit uart: Energy Detected W
[00039766]Summit uart: cnt = 58
[00039778]Summit uart: W = 8 RD Off
[00039786]Summit uart: M = 29
[00045754]Summit uart: Energy Detected W
[00045763]Summit uart: cnt = 53
[00045776]Summit uart: W = 10 RD Off
[00045784]Summit uart: M = 29
[00049760]Summit uart: Energy Detected W
[00049769]Summit uart: cnt = 62
[00049782]Summit uart: W = 14 RD Off
[00049792]Summit uart: M = 29
[00050749]Summit uart: Energy Detected W
[00050759]Summit uart: cnt = 65
[00050772]Summit uart: W = 8 RD Off
[00050780]Summit uart: M = 29
[00053779]Summit uart: Energy Detected W
[00053787]Summit uart: cnt = 53
[00053799]Summit uart: W = 10 RD Off
[00053807]Summit uart: M = 29
[00054756]Summit uart: Energy Detected W
[00054766]Summit uart: cnt = 51
[00054778]Summit uart: W = 14 RD Off
[00054786]Summit uart: M = 29
[00061790]Summit uart: Energy Detected W
[00062382]Summit uart: cnt = 53
[00062683]Summit uart: W = 8 RD Off
[00062695]Summit uart: M = 29
[00064781]Summit uart: Hop[0][0] - network quality: 44
[00064796]Summit uart: W = 12 RD Off
[00064807]Summit uart: M = 29
[00065369]Summit uart: Hop[0][0] - network quality: 94
[00065379]Summit uart: W = 10 RD Off
[00065389]Summit uart: M = 29
[00067759]Summit uart: Energy Detected W
[00067771]Summit uart: cnt = 53
[00067786]Summit uart: W = 8 RD Off
[00067796]Summit uart: M = 29
[00079754]Summit uart: Energy Detected W
[00079765]Summit uart: cnt = 59
[00079779]Summit uart: W = 10 RD Off
[00079790]Summit uart: M = 29
[00081802]Summit uart: Energy Detected W
[00081814]Summit uart: cnt = 58
[00081829]Summit uart: W = 8 RD Off
[00081840]Summit uart: M = 29
[00083740]Summit uart: CAC COMPLETE...DFS_Channel(CAC) = 20
[00083756]Summit uart: W = 29 RD On
[00083772]Summit uart: M = 20
[00085740]Summit uart: Energy pre-scan complete, enabling RD
[00148307]MAINSFAIL pin detected
[00148395]MAINSFAIL 12V fail detected
KjetilA
Posts 14
Doublepost
mbolo01
Louannec - France
Posts 2,035
mbolo01 replied on Sun, Mar 3 2019 1:22 PM
KjetilA:
I'm not a B&O engineer but it looks like both your BL 17 have the latest FW (204-1) and that at the time you did it your Core was connected to the Optical port of the TR1.
You also have ALWAYSON=1 which means that the TR1connection to the BL 17 is always on for faster start up when music starts, which also means that power consumption is somewhat higher compared to standby mode where connection is established in a few seconds when sound signal is detected by the TR1 and put back in standby after a couple of minutes of inactivity.
Page 1 of 1 (16 items) | RSS
