beo4 apple remote keymap
This post has 3 Replies | 3 Followers
Scott Needham
Paris, France
Posts 217
Scott Needham Posted: Mon, Nov 26 2012 3:27 PM
hi,
i am looking for the keymapping between the beo4 and the apple remote via the puc. i would like to double check the eventual mapping of some keys.
i can not seem to find it anywhere. is there a list or a thread somewhere with this information ?  thanks !
- scott
Scott Needham
Paris, France
Posts 217
hello,
i had totally forgotten about the archived forum.  Erm..
here is what i found :
up = up
down = down
left = left
right = right
play = go or stop
menu = exit
hold play = hold go
hold = hold exit
other hold functions do not seem to be correctly implemented. please correct if i missed something.
- scott
Keith Saunders
Hampshire, United Kingdom
Posts 5,495
Scott,
I have had a detailed look at the translation within the PUC file which was loaded into the PUC for the Apple Remote.
When you talk about HOLD I am assuming you actually mean REPEAT ?
The PUC only translates 7 commands as follows:-
·         Signal1=Plus
·         Signal2=Minus
·         Signal3=SkipLeft
·         Signal4=SkipRight
·         Signal5=Menu
·         Signal6=PlayPause
·         Signal7=Genius
The Associations of the above commands are:-
BeoButton1=play(go)                                    AlienButton1=PlayPause
BeoButton2=up                                                AlienButton2=Plus
BeoButton3=down                                         AlienButton3=Minus
BeoButton4=rewind                                       AlienButton4=SkipLeft
BeoButton5=wind                                           AlienButton5=SkipRight
BeoButton6=stop                                            AlienButton6=PlayPause
BeoButton7=exit                                             AlienButton7=Menu
BeoButton8=slow_backw                            Defined without any translation
BeoButton9=cont_rewind                           AlienButton9=SkipLeft
BeoButton10=cont_wind                             AlienButton10=SkipRight
BeoButton11=cont_up                                  AlienButton11=Plus
BeoButton12=cont_down                           AlienButton12=Minus
BeoButton13=slow_forw                             Defined without any translation
BeoButton14=7                                                Defined without any translation
BeoButton15=9                                                Defined without any translation
BeoButton16=continue                                 AlienButton16=PlayPause
BeoButton17=1                                                Defined without any translation
BeoButton18=sat(on)                                    AlienButton18=PlayPause
BeoButton19=standby                                  AlienButton19=Menu
BeoButton20=timeout                                  AlienButton20=PlayPause
BeoButton21=0                                                Defined without any translation
BeoButton22=sense_on                               Defined without any translation
BeoButton23=cursor_up                              AlienButton23=Plus
BeoButton24=cursor_dw                             AlienButton24=Minus
BeoButton25=cursor_left                            AlienButton25=SkipLeft
BeoButton26=cursor_right                          AlienButton26=SkipRight
BeoButton27=select                                       AlienButton27=PlayPause
BeoButton28=back                                         AlienButton28=Menu
BeoButton29=cont_curser_up                  AlienButton29=Plus
BeoButton30=cont_curser_dw                 AlienButton30=Minus
BeoButton31=cont_curser_left                 AlienButton31=SkipLeft
BeoButton32=cont_curser_right              AlienButton32=SkipRight
BeoButton33=cont_select                           AlienButton33=PlayPause
This is the actual translation done within the PUC
Regards Keith....
Scott Needham
Paris, France
Posts 217
hi keith,
thanks for all the great info !
yes, hold is repeat. i am playing around with plex, so have been infected by their terminology. :)   does repeat work then ?  that would be great as it would open up more commands without going through menu.
if i understand your table, the beo4 key is read on the left and apple remote on the right. so exit, standby, and back would all correspond to menu. i do not see genius in the right column, does this mean it is not implemented ?
thanks again for your expertise,
- scott
Page 1 of 1 (4 items) | RSS
