Beo Sound 5 & Beo Master
This post has 9 Replies | 1 Follower
booths675
Posts 3
booths675 Posted: Wed, Mar 6 2019 2:43 PM
Whilst I know this is quite an old system now ,( I have just bought it second hand).  I can play stored music on the system but am unable to link into radio stations, any ideas on how to rectify this?
Razlaw
Posts 4,345
Razlaw replied on Wed, Mar 6 2019 3:28 PM
There is a manual for the Beosound 5 on the B and O web page. The BS5 must be connected to the internet and registered. Page 20 of the manual should help you get started. Hope this helps.
Razlaw
Posts 4,345
Razlaw replied on Wed, Mar 6 2019 3:29 PM
Also, there is now a 24 hour phone service available from B and O to help people with issues such as setting up products. The number can be found on the B and O web page. They might be able to assist you.
gerard
Luxembourg
Posts 331
gerard replied on Fri, Mar 8 2019 12:15 AM
BM5 has to be connected to your router to have internet access, best connected by ethernet (LAN).
Come over and join us in the Bs5/BM5 forum:
http://archivedforum2.beoworld.org/forums/42.aspx
Jeff
USA
Posts 3,793
Silver Member
Jeff replied on Fri, Mar 8 2019 12:21 AM
gerard:
Does B&O still curate the internet radio station list, or was that only on the Moment? And if so, what do you do now if you want to add additional ones?
Jeff
gerard
Luxembourg
Posts 331
gerard replied on Fri, Mar 8 2019 3:28 PM
I think the list is still maintained ,
I took a picture of my settings a few days ago, Radio update date is 2019-02-23.
I don't know if the list is complete, I found every station I was looking for, but I listen mostly to 4 stations.
I do not know if there was a possibility to add own stations, I think not.
booths675
Posts 3
Thanks to all who responded, system up and running fine now. Many thanks.
Jeff
USA
Posts 3,793
Silver Member
Jeff replied on Fri, Mar 8 2019 4:10 PM
Thanks. I've heard B&O maintained a list, and users could contact them and request a station be added. I know with iTunes and my Auralic there is a list, but I don't know if it's actively curated, as in if some stations are deemed unworthy, or if some outside agency keeps a master list they use, or what. I need to look into that as it's been a subject of idle curiosity for me.
Jeff
gerard
Luxembourg
Posts 331
gerard replied on Fri, Mar 8 2019 4:40 PM
If you want to connect your BM5 to your Win10 PC its possile, by that way you may tag your ripped tracks as if they were saved on your loval PC. You havecto use Beoconnect software
gerard
Luxembourg
Posts 331
gerard replied on Fri, Mar 8 2019 4:41 PM
I may verify if a special station is in the list, which one are you searching for?
Page 1 of 1 (10 items) | RSS
