I'm looking for two Beolab 4 amplifier boards.
Or Beolab 4000 MK2
Only amplifier PCB.If anyone has it, please let me know.
Hi marexy
I have one, but it’s been retrieved from a speaker with the dreaded foam rot. Can’t imagine it would be of any use, but if you think it might, let me know
Cheers
Nigel
The BL4000mk1 amplifier PCB and mk2 are different.
The mk1 has the traditional old school STK module, where the mk2 has the ICE power PCB. Totally different design.
jap...i need 4000 MK2 board or BL4
thanks for offer :)
if i'm not mistaken BL7.2 have the same board ?
I've taken a lot of BL7-1,2 and 6 apart, but not to my knowledge are they the same.
The BL4 and BL4000 are identical as PCB, yes, but differ at the bottom connector and 2 capacitors.
sorry for BL7.2 my mistake :(
They can be new or used ..any kind..
Maybe you have some broken one you do not need as i will try to repair mine.
you can send me mail..
Thanks for any kind of good news :)
