I have a Beogram RX2 turntable type 5833 with an MMC3 cartridge. It is hooked up to a pair of Polk SDA-2 tower speakers (4 or 6 Ohms ? not sure) all driven through a Denon AVR 1508 receiver. Audio from the turntable was minimal and increasing the volume didn't do anything. Sound through the cd player and TV was fine. Was told to get a pre amp (Behringer microphono PP400) but it didn't help. I'm a neophyte with electronics so am going through a local expert who recommended a new receiver that would not need a pre amp. Am looking at the Yamaha Aventage RX-A780 or the Pioneer VSX-LX303. Would like to know if anyone knows if either of these will be a workable solution and if both, which would be the better of the 2.
The PP400 is a phono preamp, it should work. Granted the MMC cartridges are lower output than most, but it still should work. I suspect the cartridge is dead.
Jeff
Jeff:The PP400 is a phono preamp, it should work. Granted the MMC cartridges are lower output than most, but it still should work. I suspect the cartridge is dead. Jeff I'm afraid I'm recovering from the BeoVirus.
I agree, even if it was producing any signal at all it should go up and down in volume with the receiver volume control. I looked and I don't think that receiver has a phono input, but the Behringer should work fine. The Denon is a good receiver, so I wouldn't replace it, at least not until I got the problem sorted out.
Strange problem. Always good idea to check the connections, and remember the table needs a ground lead attached to the phono preamp.
There is always the possibility of a 'step-up amp' which is inserted in-between the TT and the preamp. It does what its name implies: steps up the signal a bit more for the preamp. The result is output that isn't "minimal". The step-ups originally were manufactured only in Japan - perfectly fine used ones can be purchased on eBay, but now are available elsewhere. There are also a few options that combine these functions (step-up and pre amp) as well. A reasonably priced one is available at Sounds Heavenly and is designed specifically for the Beogram line of TT. I had the same problem and this unit solved it.
