Connecting a turntable (MM) to my Beoplay A9 MKIII
This post has 5 Replies | 0 Followers
josh24
Posts 2
josh24 Posted: Fri, Mar 8 2019 6:01 PM
Hey guys
I am enjoying my new Beoplay A9 MKII a lot, but i'm curious to know if I can connect my turntable to it? Maybe through an amplifier, and if so, will it work well or isn't the A9 suitable as a speaker for a turntable?
The Beoplay A9 MKIII Connections:
1 x Line-in / Optica combi-jack
1 x EthernetI don't have much knowledge within the subject, which is why I write to you.
J
Millemissen
Flensborg, Denmark
Posts 14,680
Hi and welcome to Beoworld,
your turntable must have a preamp (RIIA preamp) either built-in or added.
Depending on the output connection, you will need a ? to a minijack cable.
N.B. There are settings in the app for the A9 to adjust the sensitivity of the line-in port of the A9.
This line-in port has autosense, which means that it will seitch to the input, once the music from the turntable starts.
If you have further B&O devices (NL devices on the same network) you can listen to the turntable from those, too.
Should you need a preamp, here is an example of how to do it:
https://soundsheavenly.com/beogram-record-players/12-pre-amp-bundle-for-bo-beogram-and-all-turntables.html
josh24
Posts 2
josh24 replied on Fri, Mar 8 2019 7:14 PM
Hi MM
Thank you for answering
My turntable is a Music Hall mmf 2.3, and it doesn't have a built-in preamp..
Should I then invest in a amplifier with build-in RIAA or should i just go with a external preamp like the one you suggested or the Music Hall mini 2 phono preamplifie
/J
Millemissen
Flensborg, Denmark
Posts 14,680
All you need is the RIAA preamp, no further preamp/amp.
The A9 has built-in active speakers, so it only needs a line signal.
The easiest thing to do, is to send Steve (SoundsHeavenly) a mail and explain what you have and want to do.
I am pretty sure he has the right solution cables inclusive.
Also name the lenght of the needed cable.
Millemissen
Flensborg, Denmark
Posts 14,680
The basics of connecting is also explained in this video:
https://youtu.be/DAMcrTDe5As
Millemissen
Flensborg, Denmark
Posts 14,680
The badics of connecting is also explained in this video:
Page 1 of 1 (6 items) | RSS
