I have a Beomaster 1900 which has worked perfectly since replacing the bulbs and capacitor (as per Martin's kit). But now when I switch it on at the power switch, a lot of lights come on immediately (it doesn't go to standby). When I press on 'standby' there is a loud clicking noise somewhere beneath the power switch, but it refuses to go to standby and switches back on again. Any advice? Parts that can be replaced? I see my bass slider light is also off again so I will have to replace that too.Many thanks,Henry.
Check IC9.
